HI,
My Shadow is protesting. When I fire up the game "Slam tilt swith stuck" now appears...
OK. Went into switch test mode, all switches register fine, even the two slam tilt switches. I disconnected the connector from the board to the cabinett, switched on and off - no Slam tilt message... All voltages ok out from the board... This would clear the boards in the backbox being the suspects I reccon.
I isolated the problem by: First cutting the cables to both slam tilt switches in the cabinett excluding them.
When coin door is open the top white switch interlock pin at the side when pressed is what triggers the Slam tilt stuck message.
The wiring continues to the coin door inteface board... Meassured all diodes when game was on but D10 flows both ways.
I removed the board and meassured D10 again. Now it is suddenly fine..(!?)
1. Bit puzzled... Would a "bad" diode not be able to withstand the game current but still able to resist the lower voltage from a multimeter ? I will change the diode nevertheless but am wondering if I'm on the right track.
2. Parallel to this, there is no G.I, no lamps are on anywhere, not even in the backbox.... Is this a separate problem or has the game "locked" thinkig it has been slam tilted ?
3. Are the coin door intelock switches prone to go bad ?
All fuses are OK.
Any input and suggestions what else to look for highly appreciated.
reg
Matt
