As you see highlighted on the pic. My coin door has a “pad” under what I believe is the slam tilt switch.
When I took my door apart for restoration, this pad came off and is damaged and I am not sure if there is a need to put a new one on or not. If so, where can I find this “pad”?
It’s a square adhesive pad with a hard (plastic??) top layer
I have a Pinbot btw.. in case it matters
