(Topic ID: 193941)
slam tilt switch closed on indy 500
By lanfeust
6 years ago
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 6 years ago by GRUMPY
#1 6 years ago
Hi everyone,
I recently brought home an indianapolis 500 which was supposed to be functional.
Unfortunatly, when I power it on, it says: " SLAM TILT SWITCH IS STUCK CLOSED".
I can not enter into the test menus, game is stucked on attract mode, and obviously , the slam tilt switch is not closed.
So I am looking for advices to help me resolve this problem. thanks.
#2 6 years ago
Start with some checks:
- the 12Volt regulated on TP3 or Fuse F115 on the powerdriverboard.
- wrong plugged connectors on CPU board
- battery corrosion on CPU board
#3 6 years ago
Are any other switches showing wrong. Could be diode is bad... easy to check and a 0.10 c repair if true. But maybe not...
If you have a cap across the switch thats an even more likely cause. Even if it tests with no continuity clip it and see if it fixes (but I think maybe no diodes on this era- I only have earlier bally to look at).
#4 6 years ago
Quoted from lanfeust:
It could be that the slam switch is stuck closed from the move. Very easy to confirm.
#5 6 years ago
I tested the cpu on another pin, it's fine
I checked the continuity from J205, J212 to the coin board, and to the slam tilt. Everything is ok.
I checked the switchs of row 1 and column 2, looks good too (but I did not check the diode).
From what I read on different same subject, it seems to be located around coin door and cpu connectors...but I don't know what else to check...
I am pretty sure it's nothing, butI I am really stucked with this damn problem....
#6 6 years ago
Did you know that there is 2 slam tilt switches.
€ 17.50
$ 22.50
bdash's bits
$ 9.99
$ 22.50
Magazines/books
Pinball Magazine
$ 17.50
Hardware
$ 5.00
$ 12.00
arcade-cabinets.com
$ 329.99
Filament Printing
$ 37.50
$ 54.96
$ 12.00
Tools
Nezzy's Pinball Prints
$ 18.95
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/slam-tilt-switch-closed-on-indy-500 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
