On my CV, I am getting a Slam Tilt during gameplay only when the ringmaster is in the down position (switch 44) and the left lane switch is activated (switch 41).
I replaced the diode on both of these switches, but it didn't fix the issue. I am not sure what to try next, and it is confusing that they are both in the same row of the switch matrix but not right next to each other.
Working on the switches in the ringmaster assembly is tricky since it is not easy to access them, so before I start replacing more diodes in that row I wanted to see if anyone had any suggestions.
Also, it should be noted that none of the slam tilt switches are closed, so I don't think it is related to those switches.
Thanks in advance!
