Hi,
I am finally getting to addressing my last set of problems on my Skyrocket. In general things work except:
1. Start button on coin door has always been inoperable. I am able to reset by hand hitting reset and game over relay.
2. Out holes never kick out consistently. All 3 of them.
I was able to diagnose #2 as the score motor home switch never engages and the motor seems to stop just shy of home all the time. If I hand adjust 1 cm to the indent for home it works like a champ. All the out holes kick.
I have checked the entire cam 1 stack and it looks good with continuity. I am not 100% sure but believe the problem possibly to be elsewhere.
Here is part of the schematic and the sad state of the coin door. Maybe these are related? All steppers have been cleaned and adjusted and are belived to be working well. I can play a game manually and the ball count unit works again only if I hand move the score motor to home.
Let me know if you have any ideas. I have not had luck with bally's in the past without resolving the coin door so am trying to figure out if here is a relationship on my score motor homing and the sad state of the wiring in the door.
