(Topic ID: 152117)
Skyrocket - 10 point circuit problem.
By pauloz
8 years ago
  • 12 posts
  • 5 Pinsiders participating
  • Latest reply 8 years ago by pauloz
#1 8 years ago
Working on my Skyrocket with a friend to get it ready for a big meet in a couple of weeks. All we did was change some posts on the left sling bank and replaced a few bulbs.
When we went to play test it, the lights were on but the ball wouldn't launch and the flippers were dead. A fuse was blow so we replaced it and all good until the ball his the slings for 10 points (any 10 points score on the playfield) and the cools stopped working. We checked the backbox and manually activated the 10 point coil and the fuse blew again and everything went out.
Were stumped. Anyone have any ideas?
Cheers
Paul
#3 8 years ago
check for burnt coils on the 1st player 10 point score reel , 10 point relay , 10 point chime (if it has one) and the 00-90 match unit.
#4 8 years ago
Did it work before? Re check everywhere you took apart and make sure you didn't short out a connection. (Metal to metal) maybe a light socket is touching a wire on your slingshot?
#5 8 years ago
Quoted from V_piscopo:
Yes it was working before.
#6 8 years ago
Recheck those lamp sockets and posts and see if you created a short somewhere.
#7 8 years ago
Thanks for the assist guys. Gives us something to go on. Cheers Paul
#8 8 years ago
Quoted from pauloz:
Are you referring the the 10 point relay or the 10 point score reel?
#9 8 years ago
Quoted from Chrisbee:
The switch just to the right of the coil at the bottom right of the 2nd photo.
#10 8 years ago
Those 2 bottom coils are both burned. not sayin thats your problem, but I would change them both...something has caused them to stay locked on too long.
#11 8 years ago
So that is the 10 point RE. with the machine off you can meter that coil with your DMM, should be around 30 ohms. if you get 0 ohms check the hold SW white/blue wire, both the contacts and the solder lugs.
Best way to work on EM's is to eliminate, here we are starting with the 10 point RE. After that i would look at the lower (Left) rebound SWs, as this is an area that you have recently worked on.
Edit . I should have also said, remove the coil fuse before testing that coil. This give you an open circuit, takes the transform out of the circuit.
#12 8 years ago
Thanks for the help everyone. My mate has got it working again. Had to change a few coils and fix a few previous dodgy repairs but it is now going again.
This page was printed from https://pinside.com/pinball/forum/topic/skyrocket-10-point-circuit-problem and we tried optimising it for printing. Some page elements may have been deliberately hidden.
