(Topic ID: 25591)
Skypilots Rotisserie Plans (storable option)
By Skypilot
7 years ago
  • 116 posts
  • 45 Pinsiders participating
  • Latest reply 4 months ago by Mbecker
  • Topic is favorited by 174 Pinsiders
    There have been 54 images uploaded to this topic. (View topic image gallery).
    There are 116 posts in this topic. You are on page 2 of 3.
    #51 3 years ago
    If anyone has more build pics or any tips please post them. I may tackle this this weekend.
    #52 3 years ago
    Quoted from Shredso:
    PM or post any issues. I'm more than happy to help
    #53 3 years ago
    I'm putting my list together. I'll post some build pics as I make progress. Can't get a full sheet of ply into my Traverse so hopefully I can borrow a truck tomorrow. How do you feel about using pocket holes? I recently bought the jig and I've only used it a couple times.
    #54 3 years ago
    Love it, Have one myself. I strongly suggest a good wood glue when you assemble it.
    #55 3 years ago
    I'm almost done. The pocket holes worked out ok. I ended up adding some additional screws. If I planned better I could have done all pocket holes. It's only the 2nd time using the jig and I was a little sloppy. My cuts aren't as precise as I would like. It's my first time working with hardwood plywood. It chips very easily. I upgraded the blade in my circular saw, I think that helped a bit. I made some rookie mistakes with the roundover on the router but I like the soft edges. I still need to add the pivot nut, dowel lock and aluminum angle. Tonight I'm going to see how it takes stain. In hindsight I wish I marked some measurements before I cut the angles and rounded the edges.
    Overall a fantastic set of plans. I spent a lot of time trying to make sure the important parts were square, the rotisserie turns very smooth, much more so than my old black iron one. I just donated $25 to the Greater Boston Food Bank. I'll post some pics after the stain.
    #56 3 years ago
    Fantastic
    #57 3 years ago
    First coat of stain applied. I hope I can get away with 2 coats, that took a lot longer than I anticipated.
    #58 3 years ago
    I'm pretty much done. I'm thinking about adding a french cleat system around the perimeter and making movable shelves for screwdrivers/nut drivers, soldering station etc. The playfield is sitting a little high on the aluminum angle. I'll have to recess it. I can see how the dowel lock could wear out fairly quickly. How is the acrylic holding up?
    #59 3 years ago
    The acrylic was a great fix. the table locks nice and tight. Your rotisserie looks great!
    4 months later
    #60 3 years ago
    This thing is the shizznit. $50 to the local food bank. Best. Rotisserie. Ever.
    #61 3 years ago
    Quoted from Mk1Mod0:
    That looks great!
    #62 3 years ago
    I have finally assembled all of the scrap steel I need to make a rotisserie. I don't have a welder but do have a complete wood shop.
    hum, I might be rethinking my plan.....
    Great design!
    4 months later
    #63 2 years ago
    Looks like a fantastic product.
    Anybody who's built one remember how long it took to put it together?
    #64 2 years ago
    Once I finalized my version in size and design, took two days from raw wood to finished product. I have all the tools and a good amount of experience... your results may vary.
    #65 2 years ago
    Quoted from chadderack:
    I'm building right now.. super easy to follow. It's pretty quick with circular saw, also used table saw. Maybe an hour to an hour half to mark and make all the cuts, bit of sanding time. Another couple hours to glue & screw everything so far. I'm almost done minus the angle iron cut, finishing bolting the Susan's.
    #66 2 years ago
    Finished! Thank you skypilot!!! I am liking this design!! Few things I noticed (for others):
    I used 1" bolts to fasten the Susan, left just a bit fast the nuts once tightened up, worked well.
    My angle iron is wimpy, going to find the solid alum and replace it. Also found that I lacked a good way to cut the metal, and went with sawing two channels on the sides to accommodate the angles. (Well 4 technically as I mis-measured.)
    Finally I used an old flipper bat to lock the table. Should be able to throw a bushing on the other side, but I need a new bat as this old Bally one is chewed to shit.
    #67 2 years ago
    The basic construction of this is very simple. You could have a a working rotisserie easily in half a day. I took some extra time making sure measurements were close to exact, using a router to round over corners, staining it, etc. Mine is in a living space. Maybe took me 6 hours?
    #68 2 years ago
    Builds rotisserie and his initials are KFC?
    LOL, finger licker.
    #69 2 years ago
    The reason I asked the original question is of course, you measure how much stuff costs sometimes by your work rate. If this thing takes half a day to do, what is that in work dollars? It's coming out pricey that way for me, but on the up side it looks like the best model there is. I did buy a pre-made one from a pinball supplier a few weeks ago... we'll see how it goes and if the money saved will have been worth it.
    If the one I bought turns out to be a P.O.S., I'll definitely build a pimped out Sky Pilot model.
    #70 2 years ago
    I guess that makes sense if you otherwise would have been working during that time.. it's a different rate for me since I would otherwise be doing some other project. Free time is awesome but I value it less than a work hour I think.. especially since doing these things yourself is pretty rewarding
    #71 2 years ago
    Made this last year. Plan on T-molding and paint this summer.
    #72 2 years ago
    trekie I'm seeing some things I like there, very sharp! That second shelf is awesome, and I love the ice cube trays for parts sorting.. may have to get some more.. and here I thought they were only good for my manhatten ice cubes ha!
    #73 2 years ago
    Quoted from Mbecker:
    Yeh, that second shelf and the ice cube trays are the bomb!
    #74 2 years ago
    Quoted from Trekie:
    I was trying to figure out a way to get some storage on the sides, wood wasn't beefy enough for anything I liked. Magnet strips are brilliant. Can you rotate it with the shelf in place or do you have to move everything off of it?
    #75 2 years ago
    https://pinside.com/pinball/forum/topic/show-and-tell-your-diy-homemade-tools/page/4#post-2936793
    Thought this should be added to this thread.. I'm liking the addition skypilot - going to have to try something similar
    #76 2 years ago
    I made a bunch of accessories for tool storage that mount along the sides. They're really helpful, and swap out as needed. Unfortunately, the tools will fall out if forget and flip it upside down first. Amazing how many times I still forget and do that, lol. I was thinking of adding a velcro strip or some elastic pockets for some tools instead of a magnet, but the same idea.
    https://pinside.com/pinball/forum/topic/my-pinball-rotisserie-is-finished#post-1233251 post #39
    #77 2 years ago
    Yes I rotate the pf with out tools coming off. The mag strips come from HB. Pretty strong.
    #78 2 years ago
    I would like to thank Sky Pilot again for sharing his brilliant design with us.
    Donation made to the local food bank.
    #79 2 years ago
    Quoted from Trekie:
    You are welcome.
    In the coming weeks I will be building a more storable unit. I will do my best to document it .
    2 months later
    #80 2 years ago
    Finally got my units finished.
    I made two, so I can easily do playfield swap overs. I built them a while back, but hadn't assembled them.
    Last weekend I finished them off.
    I made them out of scrap MDF board, and while they a look a bit ropey they do the job admirably.
    Cheers for the plans! Donations have been made!
    rd
    #81 2 years ago
    Awesome. Someday....
    #82 2 years ago
    I was asked to make one of these for a friend. I added the blocking so the sides could be removed and the unit could be stored. General Pinball 040 (resized).jpgGeneral Pinball 039 (resized).jpgGeneral Pinball 038 (resized).jpgGeneral Pinball 037 (resized).jpgGeneral Pinball 036 (resized).jpgGeneral Pinball 035 (resized).jpg
    #83 2 years ago
    Amazing work there.
    #84 2 years ago
    You should sell these! It's probably not worth the effort and work, but this looks like the rotisserie to have.
    Marc
    #85 2 years ago
    Sweet woodwork skills.
    Makes mine look like crap. Haha!
    rd
    #86 2 years ago
    Quoted from rotordave:
    rd
    The first step is admitting it to yourself.
    #87 2 years ago
    Quoted from Bryan_Kelly:
    Haha! I admit it every day.
    I slapped my two together in 30 mins, made out of an old sheet of scrap board I had lying around on my building site.
    Literally ... "hey! A sheet of wood! I'll make two rotisseries!" Saw saw saw screw screw screw! It took me longer to google search for the lazy Susan plates than to make them. Hey, I'm busy!
    Very functional!
    Very ugly!!
    My motto - function over fashion.
    As long as the playfields turn out nice, they'll do the trick for now.
    Now I've seen the dismantable version, I'm gonna make those next! I'll even buy some nice wood!
    rd
    #88 2 years ago
    Quoted from Skypilot:
    I really like the break down for storage option, I think I will be modifying mine.
    #89 2 years ago
    I do, too! Hey, Skypilot...can you redo the plans to include the storage option, since you sit at a desk answering phones all day and have tons of time to do so? And please list all overpriced Festool products that you use to complete the job. I'm particularly interested in how you round all your edges so that you don't get any splinters in your girlish hands.
    Thanks in advance.
    #90 2 years ago
    Brilliant. Modification to be forthcoming!
    Shawn
    #91 2 years ago
    Love the mod -- won't need it for a few years at least but will do it when it's ready for storage
    #92 2 years ago
    Quoted from beelzeboob:
    I don't answer phones all day . I have people to do that for me. I tend to nap.
    No Festools were used or harmed in the production and filming of this project.
    I routed all edges with a 1/4" round over bit. I also wore gloves!
    #93 2 years ago
    Sky, do you perhaps have a modified plan set for this? My only hesitation to building one has been no where to put when not in use. But THIS would slide right under my workbench!
    #94 2 years ago
    Quoted from wxforecaster:
    I will put one together and post it
    #95 2 years ago
    One Modification I need to share.IMG_3664 (resized).jpg I flipped the angle iron. This locks the playfield in. It cannot move forward and come out of the pivot bolts.
    #96 2 years ago
    Good idea on flipping the angle iron around.
    4 months later
    #97 1 year ago
    Hey Skypilot, great design! I'm working on planning mods to the design to support both standard and wide body pfs. It seems like the octagonal and hexagonal shapes on either side are more for esthetics than functionality, right? It doesn't seem like cutting them from rectangles is needed to avoid any sort of contact during rotation, but I wanted to double check with the expert.
    #98 1 year ago
    Quoted from etlandfill:
    You need the wider center to accommodate the lazy susan rollers. The ends are thinned down for a slimmer side .It would be bulky and cumbersome if left at the full 8 inches.
    #99 1 year ago
    Great, so the exact dimensions of that slimmed down area don't really matter as long as the lazy Susan fits. Thanks!
    #100 1 year ago
    Correct
    $ 12,500.00
    $ 9.99
    Flashinstinct
    $ 39.99
    Lee's Parts
    £ 55.00
    PinballToys
    $ 229.99
    PinballBulbs
    $ 109.99
    $ 269.00
    Displays
    Boston Pinball Company
    $ 64.00
    $ 22.00
    $ 248.85
    $ 249.00
    Tilttopper
    Metal-Mods
    Filament Printing
    $ 142.00
    The MOD Couple
    $ 99.99
    $ 1,400.00
    Sparky Pinball
    $ 40.00
    Funhouse Custom Lamp Out of stock
    Professor Pinball
    $ 76.95
