(Topic ID: 230897)
"skinny" shooter tip?
By drsfmd
5 years ago
  • 7 posts
  • 5 Pinsiders participating
  • Latest reply 5 years ago by Cdemuro
#1 5 years ago
I recently picked up an early Genco machine that was missing its shooter assembly. I tracked down a correct vintage assembly, but it didn't have a rubber tip on the shooter rod. The rod is significantly narrower than the standard, and thus a "regular" tip won't fit.
Does anyone make a "skinny" rod tip?
#2 5 years ago
I have some of the early screw on type but I don't think that's what you need. A workaround that was suggested to me some years back was to build it up with some electrical tape to slide a standard rubber tip on.
#3 5 years ago
On the off chance that this information will help in your search, a 1952 Williams game ( #olympics ) I had many years ago had a skinny shooter rod tip.
#4 5 years ago
Thanks guys.
AlexF - not the screw in type-- these slide on just like a modern one, just smaller. I already thought of the electrical tape trick, but it looks odd, having the disproportionately sized tip on the shooter rod.
HowardR - Thanks. I looked at the photos on IPDB and can't tell if they are the same or not.
#5 5 years ago
I had a woodrail Williams with the skinny tip and Steve at pinball resource said build it up with electric tape like AlexF suggested. It’s working fine for me.
#6 5 years ago
I go to the auto parts store and get windshield washer hose line. Chop a piece off about a half inch long and slide it onto the old shooter rod. Now a regular shooter tip fits fine.
#7 5 years ago
Caplugs 99390155 Plastic Round Cap VC-375-8, Vinyl, Cap ID 0.375" Length 0.500", Black (Pack of 50) https://www.amazon.com/dp/B077DBTLR7/ref=cm_sw_r_cp_api_i_hadcCb6Z5A0CF
Possibly try and find something like this that fits the diameter of your shooter rod.
This page was printed from https://pinside.com/pinball/forum/topic/skinny-shooter-tip- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
