Hey everyone-
Thank you for adding me to the forum. I have a Skateball machine that I have had since it was brand new in 1980. It was played regularly for about 8-10 years at our house growing up. But since then, it been very sporadically played and left dormant for years at a time. My wife and I cleaned out our basement recently and she suggested we get it working again.
So given that she has given me permission, I have been obsessing over the maintenance and repair of my old buddy! I thoroughly cleaned it from top to bottom including the playing surface. I have replaced all the rubber, bumper lights, tightened all the posts, put new acorn nut post caps on the plastics, replaced the plunger springs, end, and clip and finally a new shiny ball. I fired it up and it worked, with a few issues I wanted to ask about here.
Now, I am a novice in the world of pinball and electronic repair in fact this is the only machine I have “worked” and the extent of my “work” is outlined to the above and the occasional replacement of a bulb back in the day.
Here is a list of the items I want to address…
• The upper left flipper skips. It will operate and then jump/jitter while extended.
• The back box does not light up. (See photo) The LED score displays work and a few of the lights work. (The ones that display messages like Game Over, Match and Same Player Shoots Again). However, the Same Player Shoots Again message stays on all the time, even during game play?
• Then there are the light bulbs under the playing surface. I have several that are out, and I want to replace them, but they are darn near impossible get to and access to replace. Is there a tool or an easy way to do this?
• There is some corrosion on the battery on the MPU. (See photo) Do you recommend replacing the MPU? I saw an Alltek Bally/Stern Ultimate MPU online. Thoughts?
• And finally, and this is going to show my novice when it comes to all things electrical… do the fuses need to be replaced as they get old even if things seem to be working?
Thank you all in advance!
