(Topic ID: 131866)
Skateball Club (fans welcome!)
By mof
5 years ago
  • 381 posts
  • 84 Pinsiders participating
  • Latest reply 4 days ago by Graysonsdad
  • Topic is favorited by 29 Pinsiders
There have been 117 images uploaded to this topic. (View topic image gallery).
There are 381 posts in this topic. You are on page 8 of 8.
#351 89 days ago
Of note - the gate at the end of the shooter lane is the exact same dimensions as the gate by the spinner
#352 89 days ago
Quoted from FLASHBALL:
New to the club!! I'm missing this same exact gate as well.
But I'm not as concerned with the gate missing as I am with the LEDs ghosting and strobing. I ordered the comet warm white frosted retro bullets. They look really nice minus the ghosting/strobing issue. I am a system11 lover and have never had this issue before.
Is there an easy solution? At first I thought of the LED OCD board but that isnt designed for these older Ballys.[quoted image]
Incandescent bulbs?
#353 89 days ago
NEW Bally / Stern Lamp Driver Board with LED support
https://nvram.weebly.com/new-pcbs.html
#354 89 days ago
Quoted from Tsskinne:
Awesome! Exactly what I needed!
Thanks Tsskinne
#355 89 days ago
That was the rats nest I created when I washed it and the reason I needed pictures to be able to fix it.
well shit man... dont leave those of us with OCD hanging...
show us the picture after it has been cleaned up and organized again.
#356 89 days ago
Can someone remove their shooter gate and take a couple photos? I'll probably end up making one with piano wire.
#357 89 days ago
I have one in my populated playfield that I will make a 3d model and dimension up if that helps
#358 89 days ago
Perfect. Thanks.
#359 89 days ago
You dont need a whole new lamp board if yours works. You can either solder resistors to each controlled lamp socket, or easier yet, get a set of Seigecraft LED boards to get rid of the strobing.
#360 89 days ago
Quoted from John_In_WI:
Incandescent bulbs?
Yes, those were the best choice at least for my game.
#361 89 days ago
Quoted from FatPanda:
Just found the siegecraft boards 45$ is half the cost of the lamp driver board. Out of stock direct from siegecraft. Guess I'll put in another order with marco.
#362 89 days ago
Reach out to hhaase as he is Seigecraft and is active on the forums. I believe Comet Pinball ryanwanger also sells a version of the boards as well.
#363 89 days ago
modeled up and just have to work out the dimensioning
#364 89 days ago
here is the sketch - sorry I work in millimetres and this is fairly close without making one
- 1.4mm dia wire
- I drew the centre line of the wire form and then 1.5mm radius at each turn and then added the radius throughout the shape - hence some of the slightly off dimensions
hope it helps
and also available here for printing off a template
https://www.shapeways.com/product/NZZ3W6VA5/skateball-shooter-lane-gate-wire
#365 87 days ago
Is the only volume pot on the soundboard? Or am I just missing the cabinet pot?
#366 87 days ago
There's no cabinet/coin door volume pot on Skateball, it only has the trimmer volume pot on the sound board.
#367 72 days ago
Hi, Skateball owners.
I'm interested in finding a Skateball for myself.
I have a newer Stern now, but I would like to try my hand at reviving an interesting/fun SS game as a project.
A collector I know with a taste for SS games suggested Blackout, which led me to Skateball.
Do any of you on this thread have a game for sale or know of a game for sale in the Midwest?
Thanks on advance.
Added 71 days ago:
*in* advance
#368 65 days ago
Quoted from Jason_Jehosaphat:
Thanks on advance.
Added 5 days ago: *in* advance
I just picked up a skateball project. Complete with a mint backglass. Playfield is pretty rough. I am on the fence on whether or not to fix or sell.
#369 58 days ago
Quoted from swinks:
- 1.4mm dia wire
hope it helps
https://www.shapeways.com/product/NZZ3W6VA5/skateball-shooter-lane-gate-wire[quoted image]
I see shapeways says available in polished bronze and brushed nickel. Is that actually metal or just metallic look? Sorry I'm new to this. Didnt realize you could 3D print metal. Ha
#370 58 days ago
yes they print metal, via 0.1mm layers of metal dust then the join with applying a special glue then once finished they carefully remove the part and dip into a special liquid metal solution that goes to the areas of the glue and replaces the glue with metal.
Note about this metal part is it can be printed in metal but not ideal as not sure how it will go and typically you can bend the wireform to spring into the holes of the bracket. Since 3d printed metal is not spring metal the bracket would need to be bent so not ideal. It was meant to be printed in plastic so you have a 3d model to bend spring wire to the same shape as a tricky shape to bend to via a drawing.
also if you become a member of Shapeways (no cost or commitment) you can go to this model and download the 3d STL model for free via a "Download Product" tab and then 3D print your own to then bend to.
merely just trying to help
#371 58 days ago
Quoted from swinks:
Very helpful. Just trying to understand how it all works. Thanks!
#372 58 days ago
I’m looking for a Skateball to restore if anyone
Knows of one
1 month later
#373 24 days ago
Picked up a skateball yesterday, planning to do a pf swap. Has anyone bought one of the new CPR playfields? Pictures or thoughts?
#374 24 days ago
I just finished a swap on mine. I think it looks good. The colors are a little off which turns some people off.
Quoted from mjalexan:
#375 24 days ago
816E7B53-51BD-49DE-9C1A-192BBE0DB27F (resized).jpegBF9412E4-9451-47DD-8990-35643851E092 (resized).jpeg294AD6A6-E701-456A-B6F3-083FEB9164B2 (resized).jpeg
#376 23 days ago
loved the new pf so much I did 2 of them!!
#377 23 days ago
Man - those restores look so amazing. Now I want to start on my swap. I've got all the parts just need to get off my fat arse and do it.
#378 21 days ago
If a Skateball owner in Canada is thinking of moving thiers along soon, please shoot me a message as i may be interested. Cheers.
#379 5 days ago
Hello Skateball owners.
Im talking to someone about buying their game long distance. The game plays as it should apparently but the g.i.and backglass lighting are working (inserts, bumbers and scores all good)
Any idea what the cause could be? Dont want to commit to another money pit
#380 4 days ago
Quoted from Graysonsdad:
Possibly a burnt/bad connector or a break in the 5V somewhere? Could be a bad bridge rectifier too. I wouldnt think it would be too difficult to diagnose.
#381 4 days ago
Owner is not a pinball guy. I wont know what the problem is until it becomes my problem lol
$ 149.95
Allteksystems
Displays
PinballSolutions.eu
$ 9.00
€ 3.95
Multigame
$ 49.99
PinballElectronics.com
Third Coast Pinball
$ 8.00
Third Coast Pinball
