Just got a Skateball that has a bit of water damage to the backbox. Probably the reason the bg paint is about to start coming off. Luckily it appears no pieces are missing yet (see pic). But from the front it has that separated look in large sections.
I'm thinking I'll try to remove that nasty brown stuff at upper left, at least in the translucent part. Then blast it with three coats of Triple Thick, then use plastic wrap and weights to keep the peeling parts down while it dries.
The metal bracket is on stuck on pretty well and I don't want to try removing it. Slight rust but I'll try to polish or paint it.
I'll accept that it will always have that separated look, but if I can keep all the paint there I'll consider it a success.
Anyone have different advice?
