I'm not sure that I can make a short post on this question, so forgive me in advance if I post too much information.
I picked up this machine with the description of: works sometimes. I turned it on to find that everything works except most of the coils (the knocker and lockout work). After it being on for a bit, everything started working. This didn't last long (a couple of games). I don't remember the order, but here is what I've done so far:
Checked the test points on the solenoid driver board. All checked out fine.
Checked the test points on the rectifier board. All checked out fine.
Used a test lead to trip each coil by touching each TIP102. Only Q3, Q15, and Q19 work when the game isn't started. Only Q3 works with a ball in play.
Tested each TIP102 with a DMM. All tested fine.
Put in a known working solenoid driver board. (Same issue, but everything started working for a short time, but quit after a few games).
I retested the solenoid driver board to make sure that nothing got fried. All tested fine.
Checked continuity from the coils to J5 on the solenoid driver board. All check out fine.
Replaced the connectors on the solenoid driver board.
Replaced the header pins on the solenoid driver board.
Completed the ground mods on the solenoid driver board.
Replaced the connectors on the rectifier board.
Replaced the header pins on the rectifier board.
Replaced F5 fuse clips (they were a little discolored) on the rectifier board.
Re-flowed both the solenoid driver and the rectifier boards.
I may be missing something that I did, but I think that I including everything.
Most of the above takes place to all older Ballys that come in anyway.
I have not replaced the connectors on the MPU. That would be next, but I thought that I'd go ahead and ask for help as I take a break.
I haven't been able to get everything working, even for a short period, lately.
Thanks in advance for any help offered up.
Miles
