Hello,
My sing along is caught in a reset loop. When you start the game the score motor runs constantly and the reset bank on the playfield constantly resets. All score reels are at zero. Any help appreciated.
Hello,
I cleaned the ball count unit and here is a picture to make sure I didnt reverse it.
Also someone mentioned checking the 'third coin relay'.
The first step would be to figure out what is making the score motor run. The switches in the long red box show you which relays can cause the score motor to run:
How many of those relays are active when the game is stuck in reset?
One possibility is that the game has finished resetting, but isn't able to kick the ball to the shooter lane to start the game. The O/Ball Return relay fires when the ball drains and the Outhole switch closes. When the O relay fires, it causes the score motor to turn, and should cause the Ball Return Kicker to fire. If your O relay is active while the score motor is turning, check the two switches in the smaller red boxes. They both need to close to fire the Ball Return Kicker.
/Mark
Thanks for the info, it turned out to be two things. First, I checked the fuse near the bottom trip bank but never put it back in, secondly, the ball count unit was off 1 step, the ball count unit disc should touch the first rivet at reset, but it was off the rivet upon reset.
I recently bought a working Sing Along. It needed a light shop job. Just figured a quick cleaning and I'd be good to go. After putting the playfield back in it is stuck in reset. I don't have a schematic. Currently the 3rd chute relay is pulsing. I checked coin door switches and all seem fine. Any ideas?
Quoted from AlexF:I recently bought a working Sing Along. It needed a light shop job. Just figured a quick cleaning and I'd be good to go. After putting the playfield back in it is stuck in reset. I don't have a schematic. Currently the 3rd chute relay is pulsing. I checked coin door switches and all seem fine. Any ideas?
check the fish paper on the coin switches, if they are not in place then it uses the trip wire to complete the circuit
Quoted from pinhead52:check the fish paper on the coin switches, if they are not in place then it uses the trip wire to complete the circuit
Got it. Took me a minute to find. I bent a switch on the motor board. Must have snagged it with the jones plugs when i dropped the playfield in.
This page was printed from https://pinside.com/pinball/forum/topic/sing-along-in-reset-loop and we tried optimising it for printing. Some page elements may have been deliberately hidden.
