A Melody that I have been working on does not score an extra ball for lighting 1-4 in a color. Any ideas? It also clears out the lit numbers from the kickout if 3 or more are lit, but not 1 or 2. Is this correct? Thanks in advance for any help!
On Sing Along:
Nothing special happens when you light 1-2-3-4, but once you do light that, the hole will start occasionally lighting for a replay. The randomization comes from the match stepper, which is activated by the slingshots and bumpers. When you land in a lit hole, you should get a knock and a replay. There are no extra ball opportunities.
Once you light a number, it should always remain lit for the rest of the game. The only thing that could reset this would be a reset of the big relay banks in the cabinet and on the bottom of the playfield.
Ok. So Let me see if I understand the problems you are encountering on your Gottlieb Melody.
Problem #1: Add A Ball reward not working properly
Issue: When all four lights are lit for a color, the game does not award an extra ball when the ball activates the saucer.
Problem #2: Numbers are reset prematurely
Issue: When 3+ numbers are lit solid for any color, the numbers are cleared out when a ball activates the saucer. While this is expected when all 4 numbers are lit, it is not expected when 3 out of 4 are lit.
Are these the problems you are having with your Melody?
Marcus
Ok. So the next question is ... "Do you have a schematic?" If the answer is yes, then we can use the schematic to help troubleshoot the problem. If the answer is no, then you need to contact Pinball Resource and buy one.
Suggestion: First, determine if this is happening with EVERY Color or if it is only happening with some colors. Then make sure your ball count unit is clean and the solenoid/coil is mechanically sound. The problem is most likely caused by a dirty switch in the switch stack beneath the ball capture saucer. If you have the schematic, you can trace the path from the switch stack to the ball count unit and figure out if something else along the path is causing the problem.
Suggestion: First determine if this is happening with EVERY Color or if it is only happening with some colors. Then do some testing. Light 1-2-4, and see if it resets. Then try every combination, i.e. 1-2-3, 1-2-4, 1-3-4, 2-3-4, and see if the problem occurs for every variation. This will help you hone in on the real problem. My guess is that one of your switches is shorting against another, thus causing the "false" reset.
Good luck!
Marcus
May have to break down and buy the schematic, that was the next step if no one here could help. Ball count unit is fine, switches under the saucers are clean. It intermittently awards the extra ball on white. It also intermittently resets the numbers. Your suggestion on troubleshooting this looks good, I'll do that next time I'm working. Thanks for the suggestions!
This page was printed from https://pinside.com/pinball/forum/topic/sing-along and we tried optimising it for printing. Some page elements may have been deliberately hidden.
