New! Dark mode!
(Topic ID: 190585)
Sinbad Playfield Restoration (Fail and Recovery!)
By quinntopia
  • 198 posts
  • 22 Pinsiders participating
  • Latest reply 2 years ago by quinntopia
  • Topic is favorited by 30 Pinsiders
There have been 144 images uploaded to this topic. (View topic image gallery).
There are 198 posts in this topic. You are on page 4 of 4.
#151 3 years ago
Quoted from Pinslot:
Hats off to you, sir. Sinbad is an excellent game play wise, so all this work is going to pay off.
Thank you! I hope so! I know the playfield art really well now and can't wait to put it behind me and start playing!
#152 3 years ago
Decals! With most of the major colors now looking good, and my willingness to let some of the less than perfect but still acceptable blue and magenta areas go, I'm workon the last step!
Before the disaster with my first playfield, I had created the graphics for decals that included white letters (see post #81 in this really long topic!).
I already have scans for the playfield and have both text and a few graphics that will get decals. I've attached a file that has my black decals that I'll be applying.
#153 3 years ago
The previous 'decal sheet' was created after many attempts to match the right fonts and get everything the right size. I pretty much followed the steps that Vid outlines in his topic on Playfield resto.
One thing that helps a lot is printing test versions onto clear transparency sheets (if you remember those old overhead projectors, that's what these are made for).
So testing the size/shape, look before printing onto decal paper:
#154 3 years ago
The reason the above is a good step is that my insert circles were a bit too thick, so I went back to Illustrator and reduced the 'stroke' width to better match the real insert circles.
#155 3 years ago
As Vid recommends, when using decals, Micro Set is a terrific way to get the decals to adhere to the playfield.
I also sanded the playfield with 1000 grit where the decals were going - again, as Vid points out and many people know, decals like 'glossy surfaces, so a light 1000 grit retains some of the gloss but also gives enough tooth for the next clear layer. I did wet sand with 400 grit in areas where there were not going to be decals.
#156 3 years ago
After much fiddling with printer settings (decal paper is fairly thick so the paper settings need to be set for 'thick'!) I have my decals! The decals on the right were sent to Bedlam Creations for printing due to the white letters.
#157 3 years ago
Carefully cutting everything out....
#158 3 years ago
Apply Micro Set to playfield before applying decal.
#159 3 years ago
After giving the decal a soak, I remove it from the water....
#160 3 years ago
After sliding the decal from the backing paper, gently hold it in place and I use a q-tip to push out any air bubbles or wrinkles that might have formed.
If its flat, its good!
#161 3 years ago
Decals are a great way to replace art (not just text/numbers) if you can scan the artwork are are willing to learn or have some photoshop or equivalent skills.
I was very curious about how these hand-drawn lines in Sinbad's beard would look. They look great! Unless you have the light at a certain angle, its pretty hard to notice the difference!
#162 3 years ago
A wider view of the playfield with all decals applied. This went really well (each step in this process is filled with anxiety - I'm not kidding!) and really just required patience and care. I am almost tempted to do some more decals that aren't reall necessary because they look so awesome!
#163 3 years ago
What do they say about applying clear coat over decals? "Fine, light mists". That is....difficult....with Spaymax 2k. Because a 'fine mist' with SprayMax 2k is...orange peel.
BUT it's still important. It's still essential!
I read the warnings on the Spraymax 2k thread a while ago, and yet....I still put it on too thick.
Pictures to follow. You learn from my mistakes. My gift to the pinside community.
#164 3 years ago
This photo shows the decal freak out. Just to be clear, I did have a coat of clear on these decals. It was a light coat (aka orange peel with Spraymax!) and as it sat for a day with this coat, I sort of assumed I would be safe with a thick coat.
Yeah, I was being impatient.
Although, I've been working on this machine since March, so I think my impatience can be understood.
Unfortunately, decals don't care. Repair work to follow!
#165 3 years ago
That sucks! I've been following this thread for a while and it was going so well! I'm sure you'll resolve the issue. Will the decal be okay or will it need sanding out?
#166 3 years ago
Quoted from tomds:
Yeah, but it was my impatience and negligence this time, so I'm mostly angry with myself!
I was able to sand one out, the others had to be completely removed or partially sanded down to get covered again.
#167 3 years ago
More damage
#168 3 years ago
Damaged decals sanded down ("Same player" and one of the beard shadow line decals were fine).
Here's what they look like prior to clear coat. The weather forecast says it may get up to 70 this Wednesday, so that's what I'll wait for to put an "orange peel" coat (what you get when you apply it "thin" with Spraymax 2k) and then at least two more thin "orange peel" coats.
This may be the last 70 degree weather we see in Seattle area until next June so the pressure is on!
#169 3 years ago
My guy. I absolutely ❤ your tenacity. Keep up the great work! And hurry up with this pf so I can really start following this lol..
#170 3 years ago
Quoted from Gryszzz:
Lol! Thanks bud. Well, check back in two months and you can almost count on the entire playfield being reattached and then some other disaster befalls me and I'll be doing damn decals and touch ups again.
#171 3 years ago
Keep it up! This is inspiration for me to restore the basket case Charlies Angels I got a while back. Lower and upper cabinet are garbage, not savable. Backglass is pretty typical-fair. MPU went straight in the trash - brown and that bad. However, the playfield isn't so bad and is probably easily restorable. I just picked up an upper cabinet from a Countdown, and building a new lower is trivial in the grand scheme of things. Keep up the good work!
#172 3 years ago
Awesome work! As someone who will be doing this soon, my biggest concern is getting a feel for what a "mist, dusting, light, heavy" coat actually means. Never done any hvlp work, I would not have any idea.
#173 3 years ago
Quoted from Langless28:
Yeah, its a pain because there's really no specific way to know for sure! There are so many steps in this process it really is something you have to be prepared that you'll mess something up and have to go back a few steps!
#174 3 years ago
Quoted from Joey_N:
Do it! In truth, I wouldn't go through all of this trouble if I didn't enjoy the process (even with the setbacks and frustrations) but with the ultimate knowledge that when it's done I will have restored a cool piece of history and culture that I can enjoy and be proud of and pass on to someone else to enjoy for decades to come!
I really love the overall look of all these System 1 games, and I've actually considered focusing on collecting them! Best of luck on your project, and remember that you are preserving a piece of history as well as a really cool iconic game!
#175 3 years ago
Quoted from quinntopia:
Would you ever consider taking a video of your last coat?
#176 3 years ago
I would, but not sure if videos can be uploaded to pinside?
#177 3 years ago
Okay, after some trepidation, and waiting for the temperature to hit near 70 degrees this week I realized that I don't need to worry abou the outside temp as I can just run my Costco space heater in my small shed that acts as a paint booth now and warm it up!
So today I bit the bullet...temp in the shed was 80, and I laid down 7 or 8 (!) light coats of SprayMax 2k. I used a timer so that my first three light coats were 10 minutes between, and all the following were 15 minutes. "flash off" time for Spraymax is 10-15 minutes so I was going for precision.
My spraying technique was to basically spray about 10" from playfield going fairly quickly back and forth (with a '50%" overlap with is typical for good coverage). Each coat was a thin layer of 'orange peel' looking clear. Hard to look at that, but I have heard it will be okay.....
Here's an observation...some of my decals were not cut right up to the ink, so the transparent decal area were visible up. By the 5th or 6th coat they started to become harder to see. You can ALMOST see some shadow in the 'Copyright' text decal. Again...I kept these coats as thin as I could!
#178 3 years ago
Hmmm....Pinside is telling me that I'm attempting to post duplicates. I'm not. This is strange.
So...no more photos for now. This is annoying.
(I'm going to try and sneak the photo into this post after I created it and use the edit feature. If you see a photo below, you'll know it worked!)
#179 3 years ago
You can almost see the decal edge here...
#180 3 years ago
And here's the playfield. I need to confirm whether or not I need to sand this before applying my final medium/thick coat. The normal thing is to sand 'orange peel', but a medium/ thick coat could 'flatten' it all out anyway. We'll see!
#181 3 years ago
Man you are crushing it!!! Seriously
Impressed with your courage to take this whole thing on. It's coming along great and you seem to be learning a ton. It's part of the fun right?
#182 3 years ago
So looking forward to your next step(s).
Overall, a great thread on your part. I am appreciating the detailed comments along with the step by step photos, esp. those that show the setbacks. We are all learning as a result.
Made my way over from the SprayMax 2K thread. Thanks for doing this. I know your Sinbad is going to turn out great!
#183 3 years ago
Allright, I have learned another lesson. The fine mist coating I put down wasn't really the correct way to do it.
Here's what I did wrong:
All mist coats were allowed to "flash off". As I mentioned above I waited 10-15 minutes between each of the 7 coats. What I learned is that I should spray another, thicker "regular" coat over the light mist before it has "flashed off". That thicker coat, applied while the light mist was still "wet" would not have the orange peel texture.
If I did it that way then I wouldn't have to sand it flat after it's all dried. Which I had to do of course!
Still learning!
Although that means a very precise medium coat needs to be applied because we know what happens to decals when the clear is too thick. Ahem.
I'll be spraying what might be my final clear coat this weekend. One of the other things I learned is that it's good to have a week or two between "coats". And I think a "coat" means a can of Spraymax 2k! So that's why I'm waiting. Gives the clear coat some time to expand or whatever and finally solidify (if I recall some people wait up to six months after clear coating before even reattaching things like posts and fences).
So...a few more days!
#184 3 years ago
I got my final (?) coat down! Now I guess I can move onto the new world of polishing and buffing.
Man, it’s been a long time coming!
it wasn’t the perfect I normally get, however. I think I was a bit anxious with some of the previous applications. I did apply a light coat, just in case the decals were still too close to the top, and then after five minutes put down a nice normal coat.
You can see some of my bumps below.
#186 3 years ago
Looking good!
#187 3 years ago
This thread is awesome. My hats off to you not giving up! There is a lot to be learned in this thread, that's for sure.
Almost makes me want to try doing a restoration myself.
#188 3 years ago
After 10 years of wanting a Sinbad I'm finally picking one up this weekend. Really enjoy seeing your work here. Great job.
#189 3 years ago
Quoted from Spyderturbo007:
Geez, thanks so much!! Well, even with a terrific guide like Vid's Guide to Restoration, it is still so very easy to make mistakes. I mean, I had some pretty big set backs and at least two good things about doing this topic on my first restoration in "real time" is I can share my mistakes, misjudgements and so on, but it also keeps me accountable! I mean, once you start a topic on something like this, if I just stopped, that's like admitting failure!
#190 3 years ago
Quoted from arcademojo:
I just love the artwork on these Gottlieb System 1's. If I could I would collect every Gordon Morrison machine I could!
And I knew nothing about Sinbad, System 1 or even much about pinball except I wanted one when I won it off an online auction site in my area. It's been a learning experience!
Make sure you join the "Sinbad Club" topic and share photos of your machine!
-1
#191 3 years ago
Quoted from seshpilot:
Honestly I really enjoy this restoration process. It's not nearly as expensive or resource intensive as restoring a car (which I would have no ability to do anyway!) but there is something really rewarding in learning new skills, applying skills learned from other hobbies, and spending time trying to get it right.
And constantly fighting yourself over whether or not I need to buy one more tool! Argh!
As long as I can do it at a pace where it doesn't feel like I'm rushed or in a hurry, I will definitely have another go!
4 weeks later
#192 3 years ago
I just thought I'd check in. Not a lot of activity right now. I'm just waiting a good month since my final coat of clear and am slowly working on final sanding and polishing. I am thinking that since the playfield portion of this restoration is done (or so it seems) I may start a new topic to pick up on the project and go through some of fixes to the cabinet, reinstalling all the playfield parts and hardware and hopefully get to a fully playable machine!
I have some future playfield projects on my OXO and potentially a custom retheme idea for my 'parts loaner' Sinbad and I've invested a lot in all the different things you need to do a playfield, so there will be more in the future!
1 month later
#193 2 years ago
I love your thread and am impressed with your attention to detail. I plan to attempt a FG touch up and 2K clearing soon which will be my first. Can you tell me how you addressed your star rollovers during the clear applications? I wasn't sure what you did to keep clear out of the star area. Did you have to raise the insert at all? Thanks for the detailed info....it's very helpful. I have a SS Sinbad and love it!
#194 2 years ago
I think you should do some more Sinbad playfields now that you have the process down. On a completely unrelated note, my Sinbad playfield needs some touch up and clear coating. Know anyone who can do that for me????
#195 2 years ago
Quoted from ksmmspt:
I followed Vid's instructions on his amazing playfield resto topic and just put the removed inserts into the stars upside down when I sprayed the clear. While the clear is still wet remove the inserts. Just that easy!
#196 2 years ago
Quoted from Friengineer:
Lol! Thank you very much! This effort has been so challenging and time consuming, I definitely need more experience before I can take on any work for anyone else!
3 weeks later
#197 2 years ago
I thought I posted my decals earlier, but here they are for those that need them!
First, here are the decals that I had to send out for printing that required white
#198 2 years ago
Here are decals that are black only....
$ 289.00
$ 49.00
1,000
Sussex, NJ
$ 40.00
Arcade Arts
$ 7.00
$ 36.00
Ramp-O-Matic
$ 159.99
$ 229.00
$ 68.00
MI Pinball Refinery
$ 69.99
€ 159.00
FlipperLED
$ 48.00
$ 54.99
$ 54.99
$ 7.90
$ 229.99
$ 999.00
$ 34.00
Apparel - Unisex
Silverball Swag
$ 13.00
$ 195.00
WOZ - OZ lanes Out of stock
The Art of Pinball
