Coil is okay
Diode is okay
Diode cluster is okay
Driver transistor is okay
Switch matrix to see path on cpu is okay
Switch is okay
Repined all edge connectors
Outhole only fires if I ground and touch transistor ( no don’t say transistor is bad, new board, transistor passes when I test it)
Coil does not fire when I do all coil test.
Everything else on the game works fine.
End of ball bonus is scored so the leaf switch is fine.
What else is there to test or should I just buy the all in one board from France
