I've had the Bally Silverball Mania pb game the once worked then the trouble began. Originally everything worked except 50 pr rebound lights and the top target #s V...L...I...and S were iffy but the game could be played. Later selenoids began to fail, ended up having MPU board, selenoid and updated rectifier board.Machine was working as before for a little while then more problems with F5 fuse blowing on start up, for the lighting circuit. I removed the J1 connector and fuse did not blow telling me the problem is playfield ,checked for visible shorts to ground,even look over black box and coin lighting. Moved every wire harness away from ground wire just in case of a hidded short,replaced fuse and blew it again.I tried using the 9v battery trick to find one that wouldn't light,but light goes on and off real quick then clip falls off battery.Hoping for a better solution. I could play the game without all the lights working if need be but a bigger problem arose when diong the selenoid test I got the following selenoids dead Q4...Q8...Q13...Q14...Q9...Q10 kickers,bumpers,and slingshots. I had problems with the 1a fuse one the playfield popping and fixed that. Tried grounding driver transistors on selenoid board, and get no reaction. Please take me by the hand, or ideally let me know of any tech in my area (Western MA )who would do a service call.
