(Topic ID: 105393)
Silhouette Cameo Pinball Restorers Club!
By Curbfeeler
6 years ago
  • 480 posts
  • 90 Pinsiders participating
  • Latest reply 70 days ago by WhiskeyTango
  • Topic is favorited by 215 Pinsiders
    There have been 183 images uploaded to this topic. (View topic image gallery).
    There are 480 posts in this topic. You are on page 9 of 10.
    #401 11 months ago
    Another question, I ordered varathane spray can for clear to seal playfield before and during stenciling. Does this stuff yellow if I use as top coat? Vids guide suggests 2 part auto clear, but it is an older thread and paint compositions might be better now.
    #403 11 months ago
    Thanks, I read quite a bit of that thread. After carefull consideration and the fact I'm redoing and retheming woodrails, a little yellowing might be welcomed. More realistic or antiqued if you will. I will post my work progress.
    #404 11 months ago
    Just thought of another current issue I would have if I used 2 part clear at this time (March, 28th,2020). I would not be able to buy paint respirator anywhere.
    #405 10 months ago
    Does anyone here have a scan (or better yet cameo art) for an early Stern apron? I’m working on a Seawitch, but the scan doesn’t have to be from Seawitch since there were a number of games with the same apron, just different colors.
    #406 10 months ago
    Quoted from pinheadpierre:
    I can go by my storage and pull / scan this one from a Magic this weekend if no one else can do it sooner or this one will not work for you?
    Obviously I'll remove the vending decals first (hopefully w/o damage).
    #407 10 months ago
    Quoted from Atari_Daze:
    Obviously I'll remove the vending decals first (hopefully w/o damage).[quoted image]
    I appreciate the offer - thank you! Don’t make a special trip just yet. I’ve got an offer from another pinsider to scan an apron for me. If he doesn’t come through, can I follow up and take you up on your offer? Thanks again
    #408 10 months ago
    I received my USCutter SC2 28in cutter last week. There are some initial assembly and start up problems.
    1. Screws for the roller guides on the stand were not the right thread.
    I had to re tap 6 holes for screws that I had available.
    2. Growling upon powerup. Cutter carriage kept trying to move past right side of machine stop and would not home.
    Support phone number on website is disconnected. Website support had me remove side covers and top rail and inspect homing switch. It was ok, then I noticed the cutter carriage was not seated properly in slide rails. Must have dislodged during shipping or was not assembled correctly to begin with. The website did explain reseating of this by inserting top carriage nylon rollers into guide rail then lifting the assembly up as they are spring loaded to allow to seat the bottom 2 rollers. Put it back together, powered up and it homed OK. Phew.
    3. The Vinyl Master software becomes unresponsive and locks up.
    I had learned that you need to give it time to respond to keystrokes or button presses to keep it from locking up. Maybe my computer is inadequate but I am running windows 10 64 bit.
    4. Communication setup is wacked in my opinion. The unit comes with a usb cable but you cannot select usb communications when setting it up even though it is a selection.
    You must follow the instruction book and select serial communication even with the usb cable.
    5. Some times you need to press the local/pause switch a few times to get it to change modes (basically online offline option) The switch does work as I can here the stepper motor turn on or off, but the lcd menu doesn't always change.
    It is a nice looking machine and affordable but I wasn't expecting these problems out of the box. I did do a test cut and it worked. Now I just have to learn how to create stencils with it. lol
    #409 10 months ago
    Hi,
    I would love some help from a member of this club. I have been watching this thread from the start and thought about buying one. But I have come to the conclusion that it does not make sense as I only need it for one job/task.
    Thats why I hope someone in here can help me out. I will of course pay for it.
    I need to restore my T2 apron. The Williams design is similar on multiple games so I hope someone in hear already has done the work? And can sell me a stencil I can use?
    I have airbrush paints ready if that is the way to go if you can make a frisket.
    I really hope someone will help me out and again. I will of course pay for the work and shipping.
    #410 10 months ago
    I can provide you the vectorized apron design in PDF format for free. It is for Getaway but it does not matter as the only difference is in colors. I would send you the stencil, but it would take forever to get it to you in current circumstances in the world. So you can send the file to a pinsider within USA to cut it for you.
    Quoted from tezting:
    Hi,
    I really hope someone will help me out and again. I will of course pay for the work and shipping.[quoted image]
    #411 10 months ago
    I’ve got lots of GerberMask and can cut it if you don’t mind the shipping wait. Think you are in a Nordic country?
    You might want to read my effort at doing an apron above.
    #412 10 months ago
    So is there a quick and dirty “this is how to make your own custom plastic”? Banzai Run has one that’s both easy to break and while repros appear to occasionally get done, they also seem to suck. It looks like it’s possible with a Cameo from the things I’ve seen said, but I haven’t stumbled upon the how yet.
    FWIW, I have a Cameo 4 and I’ve done some normal sign vinyl and I’ve also done some heat transfer vinyl for shirts. I’m pretty comfortable with AutoCAD, Inkscape, and Silhouette Design at this point, but have no idea what “frisket” is and haven’t used any of the wet transfer vinyls you guys seem to be discussing. Anyone got a clear guide for the best way to do a plastic repro?
    —Donnie
    #413 10 months ago
    Quoted from djb_rh:
    —Donnie
    I’ve had success with simply printing the graphic on high quality photo paper with archival ink and then adhering the image to the underside of a piece of acrylic with optically clear adhesive film. Though I’ve used the Cameo extensively for playfield and cabinet restoration, I’ve never used it for plastic reproduction.
    #414 10 months ago
    Quoted from djb_rh:
    —Donnie
    I wouldn't use the cameo, you'd be weeding forever.
    There's a great tutorial on YouTube how to use waterslide decals to make plastics. I've made a few. Color LaserJet will provide better results than inkjet.
    #415 10 months ago
    Quoted from rygar:
    Thank you this is very kind of you.
    Quoted from dr_nybble:
    Thank you. This would be so awesome! Time is no issue. I started the restoration five years ago. So I am not in a hurry while this is the last puzzle I need to solve.
    I would love to read about your effort. Do you have a direct link?
    Sorry if I don’t understand it 100% but don’t you get a white “edge” when using photo paper?
    Do you have images of the process?
    #416 10 months ago
    I guess it depends on the graphic. I assume you mean for a graphic with transparent places in the image field? How about posting a picture of the plastic you’re wanting to reproduce? That would make advising on process easier.
    #417 10 months ago
    An apron redone in vinyl:
    https://pinside.com/pinball/forum/topic/to-save-a-sorcerer-or-how-to-spend-3000-on-a-1200-machine/page/2#post-5153916
    An apron redone by airbrush:
    https://pinside.com/pinball/forum/topic/silhouette-cameo-pinball-restorers-club/page/8#post-5382809
    An apron redone by rub-on transfer:
    https://pinside.com/pinball/forum/topic/best-method-for-apron-art#post-4012132
    Personally I'd be inclined to do rub-on transfer. Let me know which way you want to go (PM if you want me to cut paint mask for you).
    #418 10 months ago
    Did you find a scan? I can try to get one of my Wild Fyre if you need. I use the Adobe Capture app - Shapes to scan for cutting.
    #419 10 months ago
    Its not plastic but my T2 apron.
    #420 10 months ago
    Quoted from lizzyd:
    I did, thank you. cottonm4 took care of me!
    #421 10 months ago
    what do you guys use for your vinyl? I've used up what came with the cameo and am looking for new vinyl to cut and use for paint masking, but everything says "permanent adhesive" and I don't want permanent, I want a temporary lower tack so it won't tend to pull up the surrounding artwotrk when removed.
    #424 10 months ago
    I need this for a Star Gazer build so if you are able to get a file I would really appreciate it. I don’t have a cameo but a friend of mine does. This apron looks great but a bit naked currently.
    #425 10 months ago
    Quoted from Tsskinne:
    Working my way through some related projects...apron stencil is on the short list, though. I’ll post here and in the Seawitch club thread when I have something to share.
    3 weeks later
    #426 9 months ago
    I'm working on a pinball related project and have been looking at a Cameo or Cricut to make some stencils for it. I, like others are having a hard time justifying the purchase price for one project... anyone local to me own a Cameo and would be up for cutting some stencils? Happy to discuss compensation with the understanding that if the costs get to be the same as buying a Cameo I'd go that route. I've got some .ai files to work with as a starting point... and actually bought some vvivid vinyl that could be used if you are driving distance local... hit me up if you have some time/interest.
    #427 9 months ago
    Quoted from roar:
    I have a full size vinyl cutter if you need something cut out. Not sure if you get down to the Buffalo area much, not at all right now with the rona I'm sure.
    #428 9 months ago
    Quoted from Kawydud:
    That would have been super handy... boarders closed until at least the end of the month though.
    #429 9 months ago
    Quoted from roar:
    I got a practically new Cameo 3 2 years ago for $90USD on Facebook Marketplace. Or just take it to a sign shop.
    #430 9 months ago
    I’d definitely suggest purchasing one if you are on the fence. I’ve had mine for about 2 years, and it’s easily the best restoration purchase I’ve ever had. Here is a pic of a diner apron I recently did (airbrushed).
    C797736B-BA70-4348-B52B-83565A2EDCBF (resized).jpeg4D2751ED-6AF6-42E3-B69E-0339FF63E3C9 (resized).jpegA31B40EB-1243-4C46-9CCB-25886A7B8FEC (resized).jpeg4016DB6D-C45F-4123-9973-905E43E91773 (resized).jpeg27177E1C-1EF4-4976-97DE-3AD07657D209 (resized).jpeg
    #431 9 months ago
    That looks like it would have been a lot of work to weed... that's all done by hand right?
    #432 9 months ago
    Yeah. Weeding it was a ton of work, but worth it in the end. I just put a new blade on my machine, and was worried about the fine details being too small, but this thing knocked it out no problem.
    Quoted from roar:
    #433 9 months ago
    Quoted from Mneubey:
    That looks fantastic, I'd be curious if you remember your settings you used. I've found my attempts at precise fine detail like that to fail.
    #434 9 months ago
    Thanks! I used the default matte vinyl auto setting when I printed it.
    #435 9 months ago
    It is really impressive for sure... I bit the bullet last night and ordered a Cameo 4... family has all agreed they will try doing some crafts on it so it gets more use. Looking forward to playing around with it.
    #436 9 months ago
    Happy for you. I don’t think you will regret it!
    Quoted from roar:
    #437 9 months ago
    To echo the others, that's a great piece of work. I haven't yet pulled the trigger on getting a Cameo for my playfield resto, and have given only passing thought to the apron. This might be the tipping point! I'm guessing you started with a scan?
    #438 9 months ago
    Thanks! Yep, I use the hp 4670 scanner (which is essential for playfields) to scan, used Inkscape to trace, and printed in the silhouette software.
    Quoted from PinballBillinFL:
    #439 9 months ago
    Here are a couple more pics of other stuff. I always meant to come back to this thread and post them since this thread is what inspired me to go out and buy one. I had no experience with Inkscape or any other similar software beforehand. Again, it’s kind of a game changer in my opinion with pinball restoration. Would highly recommend getting one.
    4C15F8F1-E2F1-4496-8666-A730ADC06E9F (resized).jpeg058BB002-E0B7-48A7-8585-B1550A001EC1 (resized).jpegB0000E77-E361-4B57-B7A4-813D590909E9 (resized).jpeg82DAE360-A4C5-4419-9A8C-0CD3AC80612D (resized).jpeg4B162E15-8A3E-41EC-919D-8D3C3B147D8F (resized).jpegE30EAAE9-6FC9-403D-9355-26EA417A0F6E (resized).jpegEFA5025A-4A28-44AE-B64D-9C61563C7226 (resized).jpeg
    #440 9 months ago
    Your posts have convinced me to get one finally. I have used InkScape a lot, I redrew a couple of entire playfields from scratch and had them printed. In your case for the TZ restoration, did you do a stencil for each colour?
    #441 9 months ago
    That fantastic! I did redo all of the colors on the tz playfield. For some reason, I didn’t take pics of the other colors. The pic from Inkscape just has all of the layers on.
    Quoted from BJM-Maxx:
    #442 9 months ago
    Perfect! I have that scanner, and have been working with playfield scans to clean them up. I've practiced using Inkscape, but not proficient yet. Did you use the base Silhouette software, or one of the upgraded versions? I downloaded the free version just to play around with it, but have gravitated toward Inkscape since it seems more robust and easier to use for separating the colors. Obviously some version of the Silhouette software is needed to drive the cutter.
    Sure sounds like another toy in my future! Thanks for those great pics - amazing work!
    #443 9 months ago
    Free version of the Silhouette software does not allow for the importing of .svg files... I'm guessing the output files of Inkscape is an .svg? If so you will need to upgrade your Silhouette software to work with those files.
    #444 9 months ago
    Good call. I upgraded the software, and it was well worth it. If you keep an eye on slick deals, they will have a sale on it every once in a while. Considering the fact that the upgrade allows importing svg files directly, it's well worth the one time cost.
    #445 9 months ago
    Quoted from roar:
    Thanks to both. I haven't produced anything useful in Inkscape yet, so I would have stumbled on this eventually. I started by importing my cleaned up scans into the freebie software, and was not happy with how it felt, so I moved to Inkscape.
    Not sure I have the optimum workflow yet; it's been quite a learning curve. Scan, import into Gimp, clean up the scan, import that to Inkscape.. Then import the different colors into the Silhouette software, and cut.. Quite the learning curves on all these things, but I sure have seen some fantastic results posted here!
    #447 8 months ago
    Just scored a Cameo 3 on Ebay yesterday!
    Now that I've taken the plunge, has anybody experimented with practicing on materials other than the Oramask or Gerber materials? I'm just looking for some cheapo material with the idea of getting some practice with converting scans to something resembling a stencil?
    #448 8 months ago
    You can buy some pens and just draw on paper, if you just want to learn to use the software. If you want to learn to play with the settings, though, this won’t help.
    Worked for me.
    Jeff
    #449 8 months ago
    Quoted from Grangeomatic:
    Worked for me.
    Jeff
    Huh.. Never thought of - gasp! DRAWING! What a good idea! True about the settings, but as I recall, there are lots of settings elsewhere in this topic that should either work immediately, or serve as a starting point!
    Bill...
    #450 8 months ago
    I've used poster board or acetate sheets from an art supply store to cut stencils.
    $ 49.99
    $ 40.00
    ArcadeArts
    $ 114.95
    YouBentMyWookie
    $ 34.00
    Various Novelties
    Pinball Photos LLC
    $ 139.00
    Sparky Pinball
    $ 369.00
    $ 5.00
    Pin Monk
    $ 369.00
    $ 4.49
    $ 29.00
    Pinball Photos LLC
    $ 18.99
    Metal-Mods
    $ 86.95
    $ 16.50
    Playfield - Plastics
    $ 9.00
    $ 11.95
    Sparky Pinball
    $ 93.00
    CzTV Mods
    $ 40.99
    Lee's Parts
    $ 89.95
    $ 49.99
    $ 24.00
    Pinball Mod Co.
