(Topic ID: 249938)
Show us your playfield repaints!
By slghokie
  • 94 posts
  • 49 Pinsiders participating
  • Latest reply 3 years ago by slghokie
  • Topic is favorited by 39 Pinsiders
There are 94 posts in this topic. You are on page 2 of 2.
#51 4 years ago
This is a very impressive show of talent from people you don’t hear much about. I think I’m realizing I have some playfields from games that aren’t high dollar. Roller Disco for instance. I’m going to have to touch up or clear on my own. Would you guys generally outline your basic clearing steps? Or point to a thread that you followed? Mind blowing work fellas.
#52 4 years ago
I’ve read through Vid’s guide and I think that covers most of it for beginners. Personally, I don’t use budget / value line clear coats such as Omni or Nason. Their solids content is not high enough and their gloss retention is not as good. In the automotive world, they tend to fail after about 5-7 years when exposed to uv from the sun. Also, you must use proper personal protective equipment and have an appropriate paint booth to spray 2k auto paints. Isocyanates can cause severe allergic reactions and can be deadly. A home made paint spray booth made of plastic sheeting can create static electricity and cause an explosion.
#53 4 years ago
(My facial expression reading this after spraying 2pac in my homemade plastic spray booth at least 16 times yet lived to tell the tale.) Sounds like I need to change my setup!
#54 4 years ago
This one is off my current project. Color matching could have turned out a lot better and some spots look a bit wonky. In hindsight completely repainting the colored areas would have worked better. My helper also messed up and accidentally painted the kickout holes before I caught it. Oh well, lessons learned for next time.
#55 4 years ago
Quoted from Deltron:
If I sprayed enough clear on a 4x2 piece of wood that I caused an explosion I may have deserved it. Plus the orange peel would be so thick it would protect me from the flames.
#56 4 years ago
put a ground strap on that Dos Equis and you'll be alright!
#57 4 years ago
Here's the Black Hole project that I've been working on for over a year. For the playfield I mixed 7 custom colors to match the best examples hidden under posts, etc. Used a tiny paintbrush and a lot of patience. Its not perfect, I didn't seal it or level the inserts. But its mine. I installed a playfield protector and intend to play the crap out of it when I eventually finish the rebuild. Still need an inner backglass and the backbox lightboard. Both are beyond repair. Anyone help out a guy in need?
20190611_135131 (resized).jpg20190611_135131 (resized).jpg20190630_214944 (resized).jpg20190630_214944 (resized).jpg20190702_192901 (resized).jpg20190702_192901 (resized).jpg20190825_211347 (resized).jpg20190825_211347 (resized).jpg20190825_213238 (resized).jpg20190825_213238 (resized).jpg
#58 4 years ago
Quoted from slghokie:
radium amazing HH! Would love to know your technique on that. I have my grail HH to repaint and likely clear. Same kind of wear on my lower playfield.
Basically follow vid's guide. Clean it up, build up clear to fill the low areas and get a flat stable base before starting to repair art. I used frisket for all the lettering and anything with sharp lines (like the areas in front of targets). I free-hand repaired the rest. I used spraymax 2k clear (but never will again).
My restore isn't pixel-perfect to the original... for example if a mouse was missing a tail I painted a new one on that was "close enough". If I was doing it correctly I would have made waterslide decals for that. I planned to buy new playfields once they were reproduced, but it turned out well enough that I decided not to.
#59 4 years ago
before and after of my mousin around . a lot of work , but came up ok I think
IMG_0373 (resized).JPGIMG_0373 (resized).JPGIMG_0374 (resized).JPGIMG_0374 (resized).JPGIMG_0375 (resized).JPGIMG_0375 (resized).JPGIMG_0419 (resized).JPGIMG_0419 (resized).JPGIMG_0423 (resized).JPGIMG_0423 (resized).JPG
#60 4 years ago
Any of you talented guys interested in restoring my Bugs Bunny playfield? I need it done by mid december.
13
#61 4 years ago
IMG_0765 (resized).JPGIMG_0765 (resized).JPGIMG_1662 (resized).JPGIMG_1662 (resized).JPGIMG_1646 (resized).JPGIMG_1646 (resized).JPGIMG_4097 (resized).JPGIMG_4097 (resized).JPG
#62 4 years ago
Quoted from bladerunner:
Let's see a picture of it.
#63 4 years ago
Quoted from PinZig:
Here's the Black Hole project that I've been working on for over a year. For the playfield I mixed 7 custom colors to match the best examples hidden under posts, etc. Used a tiny paintbrush and a lot of patience. Its not perfect, I didn't seal it or level the inserts. But its mine. I installed a playfield protector and intend to play the crap out of it when I eventually finish the rebuild. Still need an inner backglass and the backbox lightboard. Both are beyond repair. Anyone help out a guy in need?[quoted image][quoted image][quoted image][quoted image][quoted image]
Beautiful color matching and blending !
#64 4 years ago
Quoted from wolffcub:
nice work!!!
#65 4 years ago
Finishing up Eight Ball, just gotta clear/spot clear. They wanted me to match the smokey patina of the other cream areas, so that is what I did
Bally Eight Ball progress (resized).jpgBally Eight Ball progress (resized).jpg
#66 4 years ago
Not technically a repaint, but a vast improvement:
All details are there: https://pinside.com/pinball/forum/topic/ycv-bally-playboy-au-naturel
Yves
#67 4 years ago
I need to be better about taking before pics. This one was a paid job, so I documented everything.
7C9D96C7-E009-4D43-B6A7-B16ED38BDB15 (resized).jpeg7C9D96C7-E009-4D43-B6A7-B16ED38BDB15 (resized).jpeg920D142D-0645-4CA4-B59C-0DC603371085 (resized).jpeg920D142D-0645-4CA4-B59C-0DC603371085 (resized).jpeg98790739-263F-4622-8A9F-F86B86D07907 (resized).jpeg98790739-263F-4622-8A9F-F86B86D07907 (resized).jpegFFF3D5AA-3857-4642-8CCE-DFC92DB73A57 (resized).jpegFFF3D5AA-3857-4642-8CCE-DFC92DB73A57 (resized).jpeg
#68 4 years ago
1966 Cross Town
3164E6B1-68A8-45FC-9220-E4BA658F0F20 (resized).jpeg3164E6B1-68A8-45FC-9220-E4BA658F0F20 (resized).jpegA209C1E5-B7FA-4FB1-A9CA-A8F577252B9F (resized).jpegA209C1E5-B7FA-4FB1-A9CA-A8F577252B9F (resized).jpeg
#69 4 years ago
Quoted from Arcane:
Yves
Arcane we should meet up for a beer and talk pinball and repaints. I am in Cary.
5 months later
#70 4 years ago
Jacks Open, complete repaint with water slide decals
538C2112-FA77-4494-A2B2-996D30B92CC2 (resized).jpeg538C2112-FA77-4494-A2B2-996D30B92CC2 (resized).jpegC5BFAA0B-1AAB-4781-918A-2187C5033076 (resized).jpegC5BFAA0B-1AAB-4781-918A-2187C5033076 (resized).jpeg
#71 4 years ago
Quoted from phototamer:
Also some before and after of my recent surf champ restoration that is 99 percent finished.[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
BEAUTIFUL!!
2 months later
#72 3 years ago
Here is a Strikes and Spares I just finished....(not waxed yet, after paint and spot clear complete)
S&S May 26 2020 status (resized).jpgS&S May 26 2020 status (resized).jpgS&S 500 target May 26 2020 status (resized).jpgS&S 500 target May 26 2020 status (resized).jpgS&S Center May 26 2020 status (resized).jpgS&S Center May 26 2020 status (resized).jpgS&S Pins May 26 2020 status (resized).jpgS&S Pins May 26 2020 status (resized).jpgS&S Upper Arch May 26 2020 status (resized).jpgS&S Upper Arch May 26 2020 status (resized).jpg
#73 3 years ago
One of the most difficult I’ve done.
80213CAC-7D52-4E26-806B-0C8982A592E7 (resized).jpeg80213CAC-7D52-4E26-806B-0C8982A592E7 (resized).jpeg3054A6EC-8489-4C3D-934C-FE0B8A10C2DB (resized).jpeg3054A6EC-8489-4C3D-934C-FE0B8A10C2DB (resized).jpeg
#74 3 years ago
All of these PF's look fantastic! I hope everyone is posting the paint formulas in the other thread so us amateurs can mix em correctly?
#75 3 years ago
Here is a couple of my more noteworthy repaints....
Gusher_PF (resized).jpgGusher_PF (resized).jpgDSC00528 (resized).JPGDSC00528 (resized).JPGIMG_5639 (resized).jpegIMG_5639 (resized).jpegIMG_5679 (resized).jpegIMG_5679 (resized).jpeg
#76 3 years ago
A959280D-919F-40E0-9C20-FCD2E2A9F22B (resized).jpegA959280D-919F-40E0-9C20-FCD2E2A9F22B (resized).jpeg
94668CF6-9DC6-4E39-A2DA-4B3C8BBE1D1F (resized).jpeg94668CF6-9DC6-4E39-A2DA-4B3C8BBE1D1F (resized).jpeg
#77 3 years ago
Quoted from Robo1:
Here is a couple of my more noteworthy repaints....[quoted image][quoted image][quoted image][quoted image]
Wow—impressive. Gusher and what’s the second game?
#78 3 years ago
Repainting playfields is probably the weakest part of my restoration skills. I'll amend that. Definitely is the weakest. I try to buy games where I don't have to do a lot of it, or any except minor stuff, or where a replacement is available. I've done a few though, and while they don't compare to some of the work here they came out OK. A Bally Odds and Evens which was the first game I ever restored, and a Flip A Card which was a mostly all of the playfield repaint and a total cab repaint. Odds and Evens 2 (resized).jpgOdds and Evens 2 (resized).jpgOdds and Evens 4 (resized).jpgOdds and Evens 4 (resized).jpgOdds and Evens 4 (resized).jpgOdds and Evens 4 (resized).jpgOdds and Evens 3 (resized).jpgOdds and Evens 3 (resized).jpgOdds and Evens 5 (resized).jpgOdds and Evens 5 (resized).jpgOdds and Evens 7 (resized).jpgOdds and Evens 7 (resized).jpgOdds and Evens 6 (resized).jpgOdds and Evens 6 (resized).jpg20180621_132832 (resized).jpg20180621_132832 (resized).jpg20180621_132839 (resized).jpg20180621_132839 (resized).jpg20180621_132843 (resized).jpg20180621_132843 (resized).jpg20180627_150337 (resized).jpg20180627_150337 (resized).jpg20190403_192325 (resized).jpg20190403_192325 (resized).jpg
#79 3 years ago
A few I’ve done C5571D90-82F3-427C-9057-E572A76A4384 (resized).jpegC5571D90-82F3-427C-9057-E572A76A4384 (resized).jpeg92EE0EA6-98CE-40EA-8450-081AAF5D56BA (resized).jpeg92EE0EA6-98CE-40EA-8450-081AAF5D56BA (resized).jpegADDA5C01-50D8-4C79-A553-D5FE4BE0AC01 (resized).jpegADDA5C01-50D8-4C79-A553-D5FE4BE0AC01 (resized).jpeg76964393-D9C8-4F8D-9FC3-6BD797D46DA7 (resized).jpeg76964393-D9C8-4F8D-9FC3-6BD797D46DA7 (resized).jpeg
A9B87171-4359-47E8-B64C-D068DC93E966 (resized).jpegA9B87171-4359-47E8-B64C-D068DC93E966 (resized).jpeg5C692EB9-FB93-407B-8233-5A375144EC6B (resized).jpeg5C692EB9-FB93-407B-8233-5A375144EC6B (resized).jpeg169B3076-2A4F-44C9-B05D-DAD0B94F2246 (resized).jpeg169B3076-2A4F-44C9-B05D-DAD0B94F2246 (resized).jpeg
#80 3 years ago
Quoted from brenna98:
One of the most difficult I’ve done.[quoted image][quoted image]
brenna98 is that just white paint before you repainted or is that bondo or some other product for leveling?
#81 3 years ago
Damn everyone saying "I'm not so good at this" really I thought everyone I've seen looked fantastic. I envy you guys being able to paint some of this stuff as I shake way to much to do it. I do enjoy looking at everyone's results though so please keep them coming.
Russ
#82 3 years ago
Topless Fatham. A work in progress
#83 3 years ago
Here is my 66 Cross Town
12CDD3C0-54DD-4408-8210-ECE94941038B (resized).jpeg12CDD3C0-54DD-4408-8210-ECE94941038B (resized).jpeg44070729-CB7C-4985-8C34-4DEAEA9B33E9 (resized).jpeg44070729-CB7C-4985-8C34-4DEAEA9B33E9 (resized).jpeg78E6443E-B568-43D7-A679-FDB7862257A5 (resized).jpeg78E6443E-B568-43D7-A679-FDB7862257A5 (resized).jpegAD23D6C9-E94B-49D2-90CE-0D90FA866C96 (resized).jpegAD23D6C9-E94B-49D2-90CE-0D90FA866C96 (resized).jpegC561FDFA-551A-4AB4-8C0E-614A9817276C (resized).jpegC561FDFA-551A-4AB4-8C0E-614A9817276C (resized).jpegD47EF7B5-E9A0-46F9-836C-CEE798145221 (resized).jpegD47EF7B5-E9A0-46F9-836C-CEE798145221 (resized).jpegE7B97F51-231C-4C2C-AB6C-C4D7540B697E (resized).jpegE7B97F51-231C-4C2C-AB6C-C4D7540B697E (resized).jpeg
#84 3 years ago
Quoted from cartert:
Topless Fatham.
Better than a modesty PF if you ask me!
#85 3 years ago
Quoted from SilverLiningMan:
Williams Jig Saw
#86 3 years ago
White paint. Any bare wood area needs white down first to make the colors match correctly. If you paint bare wood without doing this (except black) your colors will dry much darker, even if you matched them perfect.
#87 3 years ago
Learned a ton doing this Gottlieb Hit N Run. 1st major issue was a nasty and darkened clear coating that had to be removed. To make matters worse, previous owner slathered JB Weld on the 1st, 2nd, 3rd and home bases as shown. So many methods tried and failed on the JB removal. The slathered bases slowly showed no artwork underneath... same with pop surrounds. Lots of bleaching, frisket and keyline work to get her back on track. Learned a LOT!
Attachment-1 (resized).jpegAttachment-1 (resized).jpegAttachment-1 2 (resized).jpegAttachment-1 2 (resized).jpegAttachment-1 3 (resized).jpegAttachment-1 3 (resized).jpegAttachment-1 4 (resized).jpegAttachment-1 4 (resized).jpeg
#88 3 years ago
These are all obviously incredible.
However, I'm confused as to the overall process?
Color match > lightly sand > repaint everything > clear?
Do people typically repaint all artwork?
Or just wear spots?
I can see waterslide decals being used a lot for finer graphics.
#89 3 years ago
Great work guys ! here is a shot of part of my Space Shuttle playfield restore a few years ago.
2 months later
#90 3 years ago
Just finished up a spot on Cactus Jack's
#91 3 years ago
Quoted from dudah:
Or just wear spots?
My process is
Clean, magic eraser, clean, paint all bare wood with white, scuff areas that need paint, color match, paint, scuff the entire playfield, naphtha, clearcoat
There’s more details, but those are the basics.
I don’t care for decals.
#92 3 years ago
Mostly there on a Tee'd Off...
Tee'd Off repaint July 2020 (resized).jpgTee'd Off repaint July 2020 (resized).jpg
5 months later
#93 3 years ago
Great work on these!
What type of paints are you guys using? I'm currently working on a Laser Ball PF using Createx and was wondering if anyone had any experience using 1Shot paints. Or is Createx the gold standard for this type of work?
#94 3 years ago
Quoted from omnibuscortex:
omnibuscortex for me it has been all createx. Works well for me.
$ 29.00
RoyGBev Pinball
$ 29.00
RoyGBev Pinball
$ 29.99
Pinball Shark
Shooter rods
1,150
Louisville, KY
$ 12.00
Tools
Nezzy's Pinball Prints
Tools
$ 90.00
$ 69.00
Pinball Pimp
Decorations
$ 12.00
Tools
Tools
Other
Pin Stadium Pinball Mods
Led
Gweem's Mods
Sound/Speakers
$ 18.95
$ 7.50
Hardware
Volcano Pinball
Hardware
Retro Electro Designs
NO GOUGE PINBALL™
Other
$ 52.99
Pinball Shark
Shooter rods
$ 89.00
That Old Pinball
$ 150.00
Displays
Digipinball Shop
Displays
Brooklyn, NY
$ 3.00
Other
Displays
PinballSolutions.eu
Displays
$ 649.95
Led
$ 69.00
$ 22.50
Magazines/books
Pinball Magazine
Magazines/books
800 (OBO)
Kernersville, NC
KAHR.US Circuits
This page was printed from https://pinside.com/pinball/forum/topic/show-us-your-playfield-repaints/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
