Coin door restore with spray gun.
Found a great way to get the speckled look. I tried the "flick brush method ", had big blobs and little blobs, inconsistent . Tried aerosol can, very tricky, and one full spray and your starting over. Today I tried something new . Took mini gravity gun, took off air cap, and sprayed . It won't atomize that way so it just splatters paint out. Air pressure adjusts splatter , so you will find a good spot to spray . Mini jet us usually a 1.1 fluid tip , so small splatter .
I did use satin for first layer , and semi-gloss for speckled . Just sprayed aerosol into small container , poured paint into gun cup and sprayed. Not sure that's the right gloss I wanted , but I'm just sharing technique.
Here is a video . Not sure if vid1900 has a thread on this , but could add it , as it's easy with the right equioment.
Here is a video of me spraying :
Hope it helps . Feel free to ask for more specifics , or pm me.
