Quoted from medic7000:Any tips on removing these screws on stern coin door? Tried everything I had in the house but there is not much clearance for a socket to go in there.
You can use small needle nose pliers to loosen them a turn or two and that should give you room for your socket/nut driver to fit. Sometimes you just have to press down harder and the wall of the socket will slip over the edge. The worst part is when the screws are over driven and they are embedded into the plastic on the actual mechs. They are always in hard to reach areas making it even more of a challenge.
