Few weeks ago I got a call for a problem with a WhiteWater, Owner: "One coils doesn't work, I think it's the transistor".
So went to his location and did several tests and found that all that is driven by data D0 on PDB was not working.
On further inspection we decided that I would take the board home including CPU for external battery holder and GI header fix.
1. Corrosion at 12Vregulator Q2 + C2 and U1 has corroded D0 trace but also blanking is affected. C2 was jumpered with wire on solder-side.
2. Removed components and looks like C2 was the source of the problems.
3. After 1st cleanup a copper fragment was visible that was slammed into the circuit board. With backlight clearly visible that traces are gone.
4. More cleaning and repaired traces.
5. Sealed with UV harderner paint.
6. Components in place en ready. (headers J115/120/121 done as well and installed external batterpack for CPU.)
on location new GI connectors and machine is up and running.
