Quoted from mof:what him say? remove roll pin from plunger? need a pic...
-mof
Do you also use a punch tool with it, or is that peg small enough to get roll pins of all sizes?
-mof
-mof
I definitely thought for these for sure:
Quoted from ForceFlow:Do you also use a punch tool with it, or is that peg small enough to get roll pins of all sizes?
The peg needed to be ground a bit to fit typical rollpin hole.
-mof
Roll pins hold linkers to plungers. Sometimes the linker breaks and this tool makes it easy to remove the roll pin, replace the linker, and reset the roll pin.
http://www.pinballlife.com/index.php?p=product&id=1049
http://www.pinballlife.com/index.php?p=product&id=253
It works for most of the standard roll pins found in plungers for slings, upkickers, etc.
Quoted from balzofsteel:The peg needed to be ground a bit to fit typical rollpin hole.
The one to which I linked needed no peg modification. Works like a champ.
Red arrows point to roll pin. Lots of plungers besides flippers, have them in a pinball machine.
Quoted from cottonm4:This is a roll pin. Also called a spring pin. For rebuildable joints. Drives in. Drives out.
Plunger's Creed
This is my roll pin. There are many like it, but this one is mine.
My roll pin is my best friend. It is my life. I must master it as I must master my life.
Without me, my roll pin is useless. Without my roll pin, I am useless. I must fire my roll pin true. I must shoot straighter than my competitor who is trying to beat me. I must shoot my shot before he makes the shot. I will…
My roll pin and I know that what counts in pinball is not the shots we fire, the noise of our coil, nor the dust we make. We know that it is the hits that count. We will hit…that jackpot.
(My apologies to the US Marine Corps for modifying their doctrine.)
Quoted from lyonsden:Plunger's Creed
This is my roll pin, This is my flipper.
This is for plungers, This is for fun.
(My apologies to fans of Fulll Metal Jacket.)
Quoted from johninc:I don't get it, how does that tool work on this?
Buy another pin and you'll find out.
Rule number 1 about pin club : you do not give your spouse a roll pin.
Rule number 2 about pin club : you do not give your spouse a roll pin!
Rule number 3 about pin club :
.....I'll spare you the rest. Lol.
Not nearly as good as above, it's just what popped into my head after LTGs pic.
I just made this little table. Great for working on the underside of a playfield. It works on standard and widebody pins and also stands level on a floor. Glued together with a biscuit joiner.
Here is a 14 list of tools, many of which I have used over the years in a pinch while fixing games, especially things like using rubber bands for screwdriver torque grip for pulling stripped screws and multiple use dot magnets.
Somebody made a great video showcasing quite a few of them.
I can take no credit, but is worth your time to watch.
Sometimes simpler is better.
Pinball Lift
Credit for the basic idea goes to Pinsider PK2 at...
https://pinside.com/pinball/forum/topic/how-to-move-a-pinball-machine-alone/page/2#post-3845705
Here's my version. If you don't want to lift the back of a game, this seems like a pretty good compromise between bulk and ease of use. Details at...
Quoted from JeffZee:Pinball Lift
http://www.jeff-z.com/pinball/lift/
This is a crazy cool idea! I always try to lower the pin down on my cart and have runaway cart issues. The rocker component of this design would eliminate that issue.
That is a very clever approach
Quoted from dudah:Haven't seen this here yet.
Save some fuses while figuring out a short.
They have been on here in other posts. I have several and love them. I just have not found out where to buy them cheaply. If I could find a cheap supply I would replace all of my fuses with them.
Where are you buying yours from, please?
Quoted from cottonm4:They have been on here in other posts. I have several and love them. I just have not found out where to buy them cheaply. If I could find a cheap supply I would replace all of my fuses with them.
Amazon
After one too many instances of forgetting to remove the balls from the trough before flipping up the playfield, I made this $0.05 tool.
Pinball Trapper Keeper:
1. Using plastic perforated hanging tape (Plumbing supply, $5 for 25ft x 0.75in) and 1 zip tie
2. Created a ~3in diameter loop and zip tied in place
3. Insert the loop into the shooter lane at the ball trough exit
4. Spring tension retains the balls in the trough
Such an cheap/easy solution for a pain in the ass task.
Quoted from markp99:After one too many instances of forgetting to remove the balls from the trough before flipping up the playfield, I made this $0.05 tool.
Great DIY tool. Now what would you recommend to help someone to remember to remove it before putting the glass back on (which is my problem when doing something similar with a paper towel wad I shove in the eject hole?)
How does it work to help find the short?
Quoted from bbhenry2000:How does it work to help find the short?
It doesn't
Just means a you can blow the fuse a ton of times while you try to find the short without running out of fuses
Quoted from lyonsden:Great DIY tool. Now what would you recommend to help someone to remember to remove it before putting the glass back on (which is my problem when doing something similar with a paper towel wad I shove in the eject hole?)
Attach one of these.
That’s a great idea! I generally use a flipper rubber for this, but occasionally if you don’t get it in there just right, a ball or two will still escspe
I had to have a chip socketed & replaced & instead of installing the chip, they gave me a loose one. I hate rolling them on the table, so I took my digital vernier, measured the distance between the outside edges of the socket holes & set it to zero. I then upped the tension, put the chip between the arms of the vernier & tightened it until it read zero. The chip popped right in. And a 74xx fits perfectly in the arms.
I also had to install some c-clips but they were too small to fit my pliers, so I used the inside arms to spread the clip & slide it over the shaft.
Not homemade, but I thought they were clever uses.
Quoted from cottonm4:I use a piece of styrofoam wrapped with masking tape to keep the balls from falling out when lifting the play field. Now I need to make it taller so the play field glass will not install until I remove it from the shooter lane.
Well that’s the best one yet!
I ran into a problem when rebuilding all the System 6 boards for my Blackout where the connectors were trimmed too close to the board. It made it almost impossible to properly re-solder. The 40-pin connectors between the boards were all replaced with new connectors. For the rest I used this tool I designed to fix the connectors. I remove them all, put this spacer underneath, then lightly press them in the vise to push just a tiny bit (1/32") through the shell. It lines up all the pins nicely and only takes a few seconds for each connector. I use a vice with flat jaws and a business card taped to each side. That keeps the pins from flexing when tightening.
Once done I go over the solder side of the pins with a wire brush on the dremel and they are ready to install. There is just enough exposed to make a nice solder filet for a strong joint. Doesn't affect where the connectors plug onto the board at all.
Quoted from willbeEM:In Canada there is a store called 'Sayal Electronics' that stocks them
Do you have a part number? I work by one and could use some.
Quoted from roar:Do you have a part number? I work by one and could use some.
Tried to look it up but no pictures, just go in the store and look for the fuses, lots to choose from. If you have never gone in before give yourself an hour to look around they have a ton of good stuff, spring kits, heat shrink, soldering tools, switches, buttons...
Quoted from willbeEM:Tried to look it up but no pictures, just go in the store and look for the fuses, lots to choose from. If you have never gone in before give yourself an hour to look around they have a ton of good stuff, spring kits, heat shrink, soldering tools, switches, buttons...
They know me by name at my local Sayal I know where the fuse aisle is, just want to be sure on the part, thanks for looking .
If you look carefully you can see that my plastic fuse puller is distorted from trying to remove some fuses that were locked in some very tight clips.
Surely, there has to be something better this POS piece of plastic. And a light bulb moment happened. Several weeks prior I was at an auction and bought a box of old tools. There was a funny looking set of pliers in that box. And I thought they might be good fuse pullers. I was not wrong.
These pliers are vintage, or old, or antique. Pick your poison. They are used pliers. They are old. Made by Utica Tool company that used to make all kinds of pliers. These funny looking pliers were used by telephone company employees for working with cables. That is all I could find about them.
Their part number is: 319-B. I managed to find a pair on Ebay I bought as a gift for a friend. Utica 319-B
They lock onto a fuse and won't let go. The jaw size is just right for grasping a fuse and pulling it without breaking the glass.
I am thinking of you have a torch that you could take a pair of needle nose pliers and bend and shape them into fuse pulling pliers like this pair. I suppose that since they are metal that perhaps you could get shocked but I am hard pressed to see how you could get shocked by pulling a fuse in a pinball machine.
Quoted from cottonm4:plastic fuse puller
Mine looks like that, I'm not sure how or why it still works.
-mof
Quoted from cottonm4:I suppose that since they are metal that perhaps you could get shocked but I am hard pressed to see how you could get shocked by pulling a fuse in a pinball machine.
Never underestimate the stupidity of the generation eating tide pods and snorting condoms. (Or the ones that came before them!)
Shawn
Quoted from Mk1Mod0:Never underestimate the stupidity of the generation eating tide pods and snorting condoms. (Or the ones that came before them!)
Shawn
If you are not accident prone and can handle basic tasks like pulling fuses, a pair of these curved nose pliers have been going begging on Ebay. I got my friend's pair for $11.00 shipped.
ebay.com link: Vintage Utica KS 6305 319 B Special Unique Rare Pliers Tool Excellent
I have a ton of microfiber cloths on hand at any given time, I just wedge one of those in the shooter to keep balls from spilling out.
Quoted from cottonm4:Surely, there has to be something better this POS piece of plastic. And a light bulb moment happened. Several weeks prior I was at an auction and bought a box of old tools. There was a funny looking set of pliers in that box. And I thought they might be good fuse pullers. I was not wrong.
Just bought a pair of these I found on eBay as soon as I saw your post, he/she accepted my 12.00 offer. Thanks! I’m throwing away my plastic pullers when i get home!
Quoted from Gnatty:Just bought a pair of these I found on eBay as soon as I saw your post, he/she accepted my 12.00 offer. Thanks! I’m throwing away my plastic pullers when i get home!
Cool. After you try them, come back and tell us how you like them.
Here is something I came up with to help with re-pinning connector wafers. Sometimes getting the old pins out of a wafer calls for a third hand: One hand to hold the wafer; One hand to poke at the connector pin's release point; And a third hand to pull on the wire.
Get a couple small finishing nails and nail them into a wooden board. Anchor the board to something solid. And hook the wafer on the nails. Tape it down if you need to.
Now you only need two hands. One to poke the release point and one to pull the wire.
It is not a necessary tool but it makes the job easier. And it is cheap.
Quoted from cottonm4:Here is something I came up with to help with re-pinning connector wafers. Sometimes getting the old pins out of a wafer calls for a third hand: One hand to hold the wafer; One hand to poke at the connector pin's release point; And a third hand to pull on the wire.
Nice idea, I like it
My pcb board holder, a frame made from 2020 aluminium profiles with two adjustable profiles across for different sizes, easy to turn around with the handles and can handle quite large boards.
Two large washer clamps on each side of the board with a small washer between of about same thickness as the board, hangs on the wall when not used.
All parts except knob handle distances was bought from the shelf.
Solder holder is home made as well.
Quoted from darkpinball:My pcb board holder, a frame made from 2020 aluminium profiles with two adjustable profiles across for different sizes, easy to turn around with the handles and can handle quite large boards.
That looks great. You need to make some kits to sell
Quoted from Lonzo:That looks great. You need to make some kits to sell
A bill of materials list would be super nice to have.
Quoted from cottonm4:A bill of materials list would be super nice to have.
google search term: "aluminium t-nut profil"
http://www.modularcomponents.com.au/building-blocks/t-slot-nuts/
Cheap on ebay
Thank’s! but I don't have much time to do that, this is really easy for anyone to buy and assemble.
I'll make a list of parts and dimensions within a few days.
This page was printed from https://pinside.com/pinball/forum/topic/show-and-tell-your-diy-homemade-tools/page/7 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
