(Topic ID: 65459)
Show and Tell: Your DIY Homemade Tools
By mof
9 years ago
  • 842 posts
  • 229 Pinsiders participating
  • Latest reply 8 hours ago by PghPinballRescue
  • Topic is favorited by 298 Pinsiders
    51 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
    There are 842 posts in this topic. You are on page 17 of 17.
    #801 10 months ago
    Quoted from WJxxxx:
    https://www.amazon.co.uk/gp/product/B00MMU1384/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    I used these exact pliers for 1mm & 2mm 'Spring Steel Wire' from eBay.
    They coped easily with the 1mm, the 2mm was a bit harder and needed a fair bit of grip pressure, but they got the job done.
    I made a lot of replacement gates for the Catacomb bagatelle gate that was .055"/ 1.3 mm piano wire just by using just a pair of alligator nose vice grips. For the .093/ 2.3 mm wire, I don't have enough grip in my hands to make nice tight bends with the pliers. Hence, the large size nut & bolt wire bender.
    9 months later
    19
    #802 41 days ago
    Here is the latest version of my Redneck Pinball Dolly. Details at http://www.jeff-z.com/pinball/dolly/dolly.html
    #803 40 days ago
    Quoted from JeffZee:
    Cool, I have that exact lift in my garage & sold my motorcycle. Think I will copy your idea. Thanks!
    15
    #804 30 days ago
    I just made this. No backbox, no problem
    #805 30 days ago
    Quoted from Piso:
    [quoted image][quoted image]
    I am going to be facing this problem in another few days. Cool solution !
    #806 29 days ago
    what happened to TZ's head ?
    Quoted from Piso:
    #807 28 days ago
    Quoted from fast_in_muskoka:
    it got "lost in the zone"
    #808 28 days ago
    Quoted from j_m_:
    ...and your profile pic fits perfectly..
    #809 28 days ago
    I'm still restoring it. Keeping it for last
    22
    #810 20 days ago
    A 3D printed case.
    Not sure that you'd call it a tool, but one way to make sure you keep all your bits together when moving or storing a machine. Also guarantees you don't leave balls inside before you tip it and risk breaking plastics.
    Plus it's really therapeutic snapping them open and shut with the magnets (which I forgot to fix in before taking the pics)
    #811 20 days ago
    Oooooh that looks sharp
    Do you have a version with 4 head bolts with washers for EM's?
    #812 20 days ago
    Quoted from zacaj:
    Simple answer is no. My printer only has a printbed size of 150mm x 150mm.
    Washers will fit under the leg bolts, there's a void specifically for them, and/or keys.
    Working on a version which will take 2 long head bolts.
    Who uses all 4 headbolts anyway?
    #813 20 days ago
    Quoted from WJxxxx:
    Pretty much every game before 1980?
    #814 20 days ago
    Quoted from zacaj:
    The question was who actually USES all 4? I've encountered one time when all 4 bolts were used. Usually it's just 2 diagonally
    10
    #815 20 days ago
    Quoted from WJxxxx:
    Always use 4 on 4 player EM
    #816 20 days ago
    Quoted from WJxxxx:
    A 3D printed case.
    How do I get one (or two) of these? this is brilliant!
    Chris
    #817 20 days ago
    Quoted from WJxxxx:
    Majority of the games I've picked up have had 3-4. And I have no idea how many there will be when I go to do a pickup, so I'd need to have a case that can accommodate the max
    #818 20 days ago
    Quoted from WJxxxx:
    A 3D printed case.
    This is brilliant. I’m a woodworker so if u don’t mind I’m going to get started on a nice version done in walnut…
    #819 20 days ago
    Quoted from WJxxxx:
    Brilliant product. Like the man said, the thing you didnt know you needed. And trust me, Space invaders and the Acrylic Pin always get four head bolts.
    #820 20 days ago
    Quoted from WJxxxx:
    I always use four.
    #821 20 days ago
    Quoted from WJxxxx:
    Could you make them a little taller and stash 4 long head bolts sideways under the leg bolts? I know the printing time would increase, but I think there is some potential in the Z direction.
    This is still a great idea though!
    #822 19 days ago
    Quoted from WJxxxx:
    A 3D printed case.
    Cool, need one for appollo 13
    #823 19 days ago
    Quoted from mIkea:
    Would love to see how it turns out
    #824 19 days ago
    Quoted from SilverUnicorn:
    Chris
    Currently I'm selling them for £12.50 plus P&P, which may be restrictive sending from the UK to US? Drop me a pm if you're still interested and I'll get a quote, same applies to anybody else who may want some.
    There is also the possibility of getting them injection mould manufactured, but the set-up costs are excessive UNLESS I can get a guaranteed initial order over 1,000 (which would mean having to glue in 12,000 magnets individually!!). So unless someone like Marco or one of the manufacturer's takes an interest it's unlikely. Getting them injection moulded would also mean that you could have your logo printed on them.
    Other options include: posting the stl files on somewhere like cults3d and charge a fee to download and then you could print yourself, sell the stl file to someone who could then make and sell them themselves, or start a kickstarter to get the funds to get the moulds to have them injection moulded. Still thinking about possibilities - but overall the reaction has been positive in such a short time.
    #825 19 days ago
    Quoted from tjw998:
    Print time is already over 16hrs (for the base and lid) so anything that increases that is not really a consideration currently.
    However - seeing as the vast majority of EMs requiring 4 head bolts only have a single ball - I may have a solution that will work, just need to test it out first.
    #826 18 days ago
    Quoted from WJxxxx:
    However - seeing as the vast majority of EMs requiring 4 head bolts only have a single ball - ....
    Actually, a lot of them have 5 balls. And yes we do put them all in.
    #827 18 days ago
    Quoted from WJxxxx:
    Just provide the magnets--let buyer glue them in. But probably difficult to impossible to get 1000 confirmed buyers.
    #828 17 days ago
    A friend made me a sleeve remover. Works great. Perfect fit for removing those stubborn sleeves .
    16784494831847133851556812911399 (resized).jpg16784495222997389239688511419449 (resized).jpg16784495991371082421536381946223 (resized).jpg
    #829 17 days ago
    Quoted from pinballplusMN:
    A friend made me a sleeve remover...
    How much do you (pinside) think something like this would cost to have made? I'm sure someone could sell a small run if affordable.
    #830 17 days ago
    Quoted from jeffc:
    It has already been done. Someone here is selling them. But I cannot remember who.
    #833 17 days ago
    Cut the top off a mini-post and thin the shaft a bit...
    Use the point to apply rings to non-pointy posts...
    Lubricating the point and shaft with a bit of Windex from a Q-tip also helps.
    #834 11 days ago
    I've just been using a socket.
    #835 11 days ago
    Quoted from KenH:
    Yes, but these sleeve removers have a little ledge cut on the end for a perfect fit. Once you try one you will not want to go back to a socket.
    #836 10 days ago
    Quoted from cottonm4:
    Yes, but these sleeve removed have a little ledge cut on the end for a perfect fit. Once you try one you will not want to go back to a socket.
    Just want to give credit where credit is due PinballJunkie for a great tool. He designed and sold these on here 3 or 4 years ago before he retired, he was making them at work :p , I believe the current seller asked if he could to make and sell them
    https://pinside.com/pinball/forum/topic/show-and-tell-your-diy-homemade-tools/page/9#post-4990037
    15
    #837 7 days ago
    I changed pickups a couple years ago and hadn’t hauled a pin since. Just realized the bed is higher and my harbor freight lift table won’t make the heights. With TPF this week had to build a solution. This gets me an extra 5 1/2 inches lift and is easily removed with 4 screws.
    #838 5 days ago
    nice and solid looking
    12
    #839 3 days ago
    Wms 3 to 7 test fixture.
    #840 2 days ago
    Quoted from barakandl:
    Nice ...is this combo board one of yours?
    #841 2 days ago
    Quoted from Stretch7:
    yes. coming soon
    This page was printed from https://pinside.com/pinball/forum/topic/show-and-tell-your-diy-homemade-tools/page/17 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
