(Topic ID: 288085)
Should I swap fuses
By shakeit
9 months ago
  • 4 posts
  • 4 Pinsiders participating
  • Latest reply 9 months ago by jeffc
#1 9 months ago
Should I swap fuses.
Hello I have a space station pinball which has worked fine for 2 years. I have been checking the fuses and found that some of the installed fuses are the incorrect ones. Should I swap the fuses to correct ones. The pinball will occasionally blow a 2A 3AG SB fuse which I replace and the pinball will work fine for a few months then blow the fuse again and I replace and it works OK again. I think the issue with the fuse blowing is due to a switch on the pop bumper so I have plans to re-build the pop bumper to see of the fuse blowing issue disappears. Can anyone advise on whether I should change the fuses to the correct ones?
#2 9 months ago
Yes, definitely change to correct fuses.
Check for correct adjustment on the pop bumper switch and the coil diode.
#3 9 months ago
Look in your manual and install the correct fuses. Overfusing a table puts additional load where it doesn’t belong when there is a problem and can cause a fire.
This chart is from the manual at IPDB.
#4 9 months ago
By the way, you can install a fuse with a higher voltage rating, but do NOT use a higher amperage rating.
