I had a problem with my black knight 2000. Had a bad leg on the bridge rectifier on the power supply. Replaced it and it seems pretty hot. Is this normal?
What did you replace it with? If it's not rated to handle the current, a lesser bridge rectifier will overheat.
I will have to double check that. I went to the electronics store and brought the old bridge and told the guy "I need one of these". I'm no genius with the boards so I was pretty stoked when I got the machine working.
In summary, yes, most bridge rectifiers in pinball machines are designed to operate at their upper limits and run very hot.
A 400V, 35A bridge will pretty much work in any machine, from all eras and manufacturer. But regardless, they do run hot, some more than others depending on the circuit they are in. Typically the bridge that is for the +5V runs very hot and will have a heat sink.
I checked the old bridge rectifier number. It is kbpc3502w. It is a 35A 200V. The one I replaced it with has the same rating. It just seems pretty hot and was not sure if it should be like that. It is for a power supply for a BK2000. It is the only rectifier on that board?
Normal... if you want, you can put a heat sink on it. I normally do if I am replacing that bridge, heat is probably the reason they eventually fail.
The feature lamp bridge probably gets even hotter than that one.
This page was printed from https://pinside.com/pinball/forum/topic/should-a-bridge-rectifier-get-hot and we tried optimising it for printing. Some page elements may have been deliberately hidden.
