I recently picked up a LOTR and installed a "interactive Led back box lighting kit" that ties into the power board. It eliminates the fluorescent tube and has strips of Led's that color change and a few white flasher strips that go off with game play. Problem now is that I lost some coil functions and the flashers due to a blown 5 amp fuse. Which is due to a shorted out tip122 transistor. I really like this mod and want to run it. Doing a little research,there is a replacement tip102 transistor that is described as being "more robust". Is it possible that adding this Led light kit could cause all of this and would the tip102
fix it?
