(Topic ID: 133395)
Short in 12 volt - but where?
By oldschoolbob
7 years ago
#1 7 years ago
After working on the MPU, the rectifier board and the regulator board I installed the rectifier board and checked the voltages - all good. Then I installed the regulator / solenoid board and checked the voltages - all good. Then I installed the MPU and the fuse for the 12 volt blew. I removed the MPU and re-checked it on the bench - 6 flashes - good.
Today I replaced the 12 volt fuse and rechecked all the voltages - every thing checks good. Then I reinstalled the MPU but this time I only plugged in J4. Turned it on and I get seven flashes.
This looks like (to me) that I have a short somewhere outside the MPU that is causing the 12 volts fuse to blow. I only have one 4 amp fuse left - any ideas where too look?
Bob
#2 7 years ago
Quoted from oldschoolbob:
Was 12V shorted before you worked on the boards? What did you do on the MPU? Could the other J headers on the MPU have been affected by your repairs--like a shorted pin or bad component?
Did you make any changes to the connectors (could a pin be swapped in the wrong hole)?
Someone mentioned this in another thread, but its better to make one repair at a time and test, so when there's a problem, you know what repair caused the problem (for future reference).
#3 7 years ago
Thanks Ken,
Quoted from KenH:
I'm not real sure but I think it was shorted before - I found a blown F3 fuse when I was testing the rectifier board.
Quoted from KenH:
I repaired some corrosion and a burned hole under J4. (see this post : https://pinside.com/pinball/forum/topic/large-hole-in-mpu-100
But I'm confident the MPU repairs are OK. It checks out on the bench and I get seven flashes when it's installed with nothing else connected.
Quoted from KenH:
I did change the J4 connector because the original was burnt. And I replaced all the crimp on connectors. But I'm very careful when doing this - I mark each empty connector slot and only change one connector at a time.
I'm thinking the problem is in the sound board - it uses 12 volts - J2 pin 5 & 6 shows 11.9 volts. But J2 is connected and the 12 volt fuse is not blown.
Bob
#4 7 years ago
Is it possible for a short in the 5 volt somewhere to take out the 12 fuse?
#5 7 years ago
You could try powering up with the sound card disconnected (and everything else connected) -- but it may blow your last fuse.
You could consider these, if you do even a few repairs, these are great:
https://pinside.com/pinball/forum/topic/making-and-using-a-fuse-breaker#post-1309179
or you're probably going to need more fuses.
#6 7 years ago
Thanks Ken,
I've considered those breakers before but they seem to be a waste unless you work on machines a lot. I have plenty of 5 amp fuses but only one 4 amp left. My next GPE order will include more fuses or some breakers.
Tonight I connected everything except the sound card and it worked. I even ran the self test and played a few games (no sound). I removed the sound card and looked it over but don't see anything obvious shorted.
Any idea what would cause a short on the sound card?
Bob
#7 7 years ago
Bob,
Its probably one of those Large caps that has failed. Look for a low resistance reading to ground.
You may have to isolate the problem by lifting parts in the 12volt circuit.
#8 7 years ago
^^^^great idea.
For testing, you might be able to power it with your bench supply before you put it in the machine--save that last fuse
#9 7 years ago
Today I installed a known working sound card from another machine. The good news is the fuse didn't blow but the bad news is I have no sound. I checked the voltage at TP1 and have 5 volts - at TP7 I have 13 volts.
Is there any way to check if the sound card is producing sound?
Tonight or tomorrow I'll try the questionable sound card into the other machine and see if it blows the fuse.
Bob
Protection
Displays
PinballSolutions.eu
Displays
Troxel Repair
$ 5.95
The Pinball Scientist
Protection
Men
$ 29.00
RoyGBev Pinball
Lighting
Yoppsicle
Lighting
Cabinet Parts
Cabinet parts
$ 199.95
$ 149.95
Allteksystems
$ 169.00
RoyGBev Pinball
$ 55.00
Displays
PinballSolutions.eu
Displays
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/short-in-12-volt-but-where and we tried optimising it for printing. Some page elements may have been deliberately hidden.
