I know lots of LED fans here but there is still a place for incandescent bulbs, especially on some of the older games. Sometimes, you don't want to invest in LED bulbs and just make sure all the incandescent bulbs are working as best they can. But a lot of times the bulbs are dirty, some get mirrored/blackened and run even hotter. The best time to handle this is when you're doing a shop.
I'm in the middle of a major shop on a MMPM. I have no intention of putting LEDs in for a number of reasons. I also don't want to spend money on new bulbs if I don't have to. As part of the shop, I pull all the incandescent bulbs and put them in a small parts container/silverware holder and then put the bulbs in the dishwasher - gentle cycle, air dry. When I'm done I take out the bulbs and line them up like so:
Because the bulbs are nice and clean it's easy to see which bulbs have become mirrored, which are starting to darken and which are clear. I then test all the bulbs for continuity with the multimeter. In the photo, the bulbs on the bottom row are bad (I had a few extra 44s, 89s and 906s I threw into this wash) and the bulbs above the bottom row test fine. However, the bulbs on the right side in the second row from the bottom have started to darken. Even though they tested ok, these wound up in the trash. And the bulbs in the bottom right corner tested bad, even though they looked ok.
The rest of the bulbs are nice and shiny like new and are ready to go back in the machine. One of the reasons to do this is that these bulbs are high quality examples usually either made by GE or Westinghouse. The way I figure it is if the bulb survives in the dishwasher, it probably has several more years of service left in it.
BTW, when I'm done I always check (and clean) the drain trap in the dishwasher in case a bulb gets out of the holder. And then I run an empty load to clean out anything that may have been left behind so I don't get complaints from the wife.
Feel free to share your shop tricks as it relates to bulbs.
viperrwk
