I am helping a friend with a High Roller Casino that is having some trouble in the shooter lane. I am having major issues with the autoplunger and minor issues with the manual plunge.
The biggest issue is that the autoplunger fails to get the ball up the ramp 1 out of 5 times. If this happens during multiball, occasionally you get two balls in the lane and then you're stuck.
The issue is that the ball is coming off the autoluancher forks to the right, then bouncing on the left side of the ramp and losing a lot of momentum on the way. The video shows it happening.
The autolaunch mech is all new and the ball seems to be resting on the forks well. I don't have a pic because I have tweaked it in so many positions, to no avail.
But...the plunger also occasionally has the ball bouncing up the lane. Less of an issue on the manual plunge because it is stronger than the autolaunch.
Is there a recommendation for how to tune this up / tips on positioning?
thanks!
