Hoping someone can help me out with a part I dont know whats called! Is the metal piece/bracket that sits atop the shooter rod/nipple area. On my new stranger things LE its hanging a bit low which causes the rod to make impact with it and the launch sucks. In one pic you can evem see its shaving away at the metal a bit. Id like to know how to adjust that? It seems to me the spring just needs to be slightly more springy which would make the bracket rest at the right angle....Is that what I should try? Or something else? I have videos which show it better but cant attach them to a forum post.... Its just a few mm off which is causing the issues.
20210423_183414151_iOS (resized).jpg20210423_183414151_iOS_LI (resized).jpg20210423_183440040_iOS_LI (resized).jpg20210430_001604152_iOS (resized).jpg
