Need to ship some unboxed pins and trying to figure out what is the best option for straps. Would you recommend ratcheting nylon tie downs or polyester plastic tie downs using a poly tool to tighten the straps? Freight harbor carries the ratcheting nylon tie downs but not the poly tie downs. Any recommended source(s) as to where I can buy these? The poly tool can be quite expensive. Hoping the ratchet tool is a good option to go with. Thanks in advance.
