In the home stretch of getting a Ship Ahoy up and running. Really wanted to get one done without having to ask for help, but I'm good and stumped.
First off - Ship Ahoy is an add-a-ball game. But it uses WOWs instead of having a ball count the can step up and down from 0 to 9. I have it on 5 balls, so at the start of a game you're on ball five and will run through them. When you earn an extra ball, the ball count doesn't actually increase. Instead, a separate stepper increments and you light a WOW on the backglass. You can earn up to 5 WOWs at a time.
If you're on ball three and earn say 3 wows, when you drain, the ball count stepper would remain on ball three and one of your wows would be used up.
The issue I'm having: If I have a single wow - when the ball drains, the wow is taken as expected, BUT it's also then decreasing the ball count. This happens no matter which ball I'm on, and ONLY if I have a single WOW.
There are two earlier threads on pinside that I found describing this exact problem.
In one the issue solved itself via black magic and luck or something:
https://pinside.com/pinball/forum/topic/ship-ahoy-earns-wows-but-no-extra-balls-given
In the other, some in depth posts were made regarding where to look, but there's not really any resolution:
https://pinside.com/pinball/forum/topic/lose-ball-with-wow-lit
Looking at the relevant bit of the schematic - it's pretty clear how things should be working:
At the zero position, the 2nd switch on the wow stepper is closed, allowing the ball count stepper to decement on ball drain.
If the wow stepper is at 1 or above, the switch is opened and in theory, the ball count stepper shouldn't be able to activate.
here's some pics of the lightbox advance switch stack in three positions.
0 wows - reset complete.
With 1 wow - where the issue will happen.
With 2 wows - switches the same as with 1, the peg is just further away.
Video of the issue - please ignore my middle aged grunting as I tried to squeeze past a pinball machine in my ktichen.
What seems to be happening is that with a single WOW, as the Wow unit steps down, right at the 2nd switch closes, it's causing the ball count unit to step down as well. I have no idea why though and don't know where else to look. I mention it in the video, but I've adjusted that switch many times - trying to get it just barely closed when the wow unit steps down, leaving it as open as possible when the wow unit is at 1 or above. The ball count keeps stepping down regardless.
Any suggestions?
