(Topic ID: 299807)
Share Tech info please WPC-89 driver board A12697-1
By bepositive
2 years ago
    #1 2 years ago
    Greetings recent entry of the new "Genuine William and Bally replacement board" company launch brought up some questions for me . I'd like to start this thread with the topic concerning the single Williams part number A12697-1 utilized for all 3 versions of the WPC-89 driver board per PinWiki .
    Non Fliptronics driver board version likely can be identified observing the built in flipper relay as a visual clue .
    My Creature from the Black Lagoon has the OEM driver board ( I bought out arcade years ago so I know its history ) with a relay on the driver . PinWiki shows games is Fliptronics 2. Interesting . This leads to the two following questions .
    Is there a way to visually inspect A12697 to differentiate between different Fliptronics versions ?
    A12687-1 Driver board . Is there a rule or chart which driver board versions are forward or backward compatibility ? Chapter 7.1 PinWiki none observed .
    Please use this thread for information sharing not teething issues with the startup company . No intent to bash just learn something . I am confused on this issue and have been collecting pins for 28 years . Likely others have good questions , expertise and broader experience . Please add to the knowledge base issues you have observed with the A12697-1 driver and what you had to do to get things fixed . I feel lots of new blood in the hobby now . They might like to know what can go wrong with the driver . Bad header pins / Trifurcon pins needed , bridge rectifiers issues , wrong mounting screws causing resets type of thing .
    https://www.pinwiki.com/wiki/index.php?title=Williams_WPC#WPC-89_.26_WPC-S
    Thanks in advance for your help Shane
    PS copied Forceflows link since I am lazy Thanks
    #2 2 years ago
    TAF and older games that have flipper leaf switches need the -1 driver board for the flippers to work, which is the reason for the flipper enable relay.
    -1 driver board can be used in any WPC game. It is useless really having a -1 driver board in a Fliptronix 2 game that has flipper opto boards because it will not ever use that flipper enable relay on the driver board.
    What issue are you having with your new Pinball Basement board? There is a warranty on the board.
    #3 2 years ago
    I believe there was a -2 version as well, with other small changes.
    From what I remember, -0 (no dash) can be used in -1 and -2 games - i.e. the board can be upgraded as needed. But you can't put a -2 in a -1, or a -1 in a -0. i.e. Boards can't be downgraded.
    #4 2 years ago
    Let me clarify . Thread not about Pinball Basement . My purchase did have me self question the driver board part number . That led to this threads purpose , better understanding the driver board and issues it can present . Let me change with thread topic to what parts you would install if doing a quality rebuilding job on the driver for resetting issue due to 5 V generation . Or maybe coil shorted and blew drive transistor . The type job one would perform or have someone fee paid service in a game you plan to keep for life . List parts you should have on hand before you pull the board
    ( assuming you do your own work ) . Like this paste from PinWiki for the GI connector failure .
    WPC-089 Power/Driver Board J120/J121 connector repair parts list...
    Qty
    Part Product ID
    2
    11 pin .156 male header (cut to size) 26-48-1245
    2
    Connector, .156 Plug, 11 pin (Molex 41695 series) 09-50-8111
    10
    .156 Trifurcon crimp contacts for the larger gauge wires 08-52-0113
    10
    .156 Trifurcon crimp contacts for the smaller gauge wires 08-52-0125
    2
    "Keying Pins" for Molex 41695 series plugs 15-04-0297
    1
    Crimp tool 1028-CT (or equivalent)
    Bonus points suggestions for proven higher quality alternate part choices with order numbers for best results .
    Either way thanks for your replies
    Shane
    This page was printed from https://pinside.com/pinball/forum/topic/share-tech-info-please-wpc-89-driver-board-a12697-1- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
