When the 3 pinballs are released in Shaq Attaq's multi-ball they roll out all at once instead of in a staggered interval. Why is this and what can be done to correct it?
Thank you for any assistance.
Quoted from Bigguy66:When the 3 pinballs are released in Shaq Attaq's multi-ball they roll out all at once instead of in a staggered interval. Why is this and what can be done to correct it?
Sorry im not to familiar with this game.Are you saying that it puts 3 balls in the ball through all at once during multi ball?Or the locked balls are just rolling out during gameplay?
I had a problem with my Shaq releasing 2 balls at a time. I disassembled and cleaned the ball release plunger. It was dirty and returning to the closed position too slowly.
Quoted from Bigguy66:Thank you for your post. Yes, all 3 balls come out at one time.
Ok then you need to test that switch in the ball through...Could be a bad switch/faulty.You can test this switch in the switch menus settings place a ball over that switch and see if it registers properly if not then there’s a problem with switch or a diode has shorted if there is one on that switch
Thanks to everyone for their suggestions as hopefully one of them will be the answer in my situation.
i believe he is speaking when you plunge all 3 balls one at a time they get locked on the right ramp, then the post drops on the ramp and releases them one at a time. Clean the post assembly on that ramp, install new coil sleeve and make sure the balls are not magnetized.
The issue has now been resolved. I initially cleaned the plunger shaft which resulted in the first pinball releasing by itself but the remaining two balls would come out simultaneously. Once in a great while all three balls would come out in the desired staggered order. I ended up replacing the coil, the coil sleeve, the coil diode, the plunger shaft and its compression spring. Now all 3 pinballs are released in the desired staggered order. It works great. Thanks to everyone for their suggestions.
This page was printed from https://pinside.com/pinball/forum/topic/shaq-attaq-multi-ball-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
