Hello Everyone! I am the proud new owner of a 1967 Shangri-la. I played a quick game on it at the seller's house and didn't notice any obvious problems. Once I got home I played quite a few games and noticed that it will activate the tilt function even though there is no plumb bob on the wire form. The horizontal tilt "ball cage" doesn't have a ball in it either. One of the switch blades is broken off from the switch that is located at the end of the "ball cage."
It doesn't tilt every game or every ball. Sometimes it will do it twice in a row and other times it won't do it for five or more games. When it does tilt it's either right after a ball is plunged and it hits a rollover target, but I can't figure out which rollover because I took the glass off and tapped on all of the rollovers repeatedly and it didn't do it. I do have one rollover that won't register a score 90% of the time it is hit and when I did get it to score it didn't tilt immediately. Sometimes it will already be tilted before you even plunge the ball. I also noticed if you are in a two-player game and it is already tilted before plunging the ball that the next players ball will be tilted before they plunge and it won't go back to be un-tilted until both players turn is over on that particular ball.
Can anyone point me in the right direction on what to check out to fix this annoying problem?
