Hi Portraitman2
I go to my Shangri La - I open the Backbox - I look towards the Player(s) - on the right in the Backbox is the 3-4-Reset-Relay mounted , see the first JPG. It is not a good picture but good enough to make some definitions. Towards me, near me - from left to right there are four switches. Away from me (towards the wooden panel) - from left to right there are four switches. So Sw-near-1 is leftmost, towards me. So I have Sw-near-1, Sw-near-2, Sw-near-3, Sw-near-4 --- and Sw-away-1, Sw-away-2, Sw-away-3, Sw-away-4.
See the second JPG - it is the 1-2-Reset-Relay (mounted on the left side in the Backbox). I unscrewed the relay and I let it hang on the wires. Also I have Sw-near-1, Sw-near-2, Sw-near-3, Sw-near-4 --- and Sw-away-1, Sw-away-2, Sw-away-3, Sw-away-4. See the stripe of paper - I have put the stripe of paper in-between the contact-points / blades in SW-near-1. Mechanically the armature and the nylon-ladder and the blades can move - BUT Sw-near-1 cannot close electrically (due to the sneaked-in stripe of paper. I have points on all the Score-Drums of Player-1 and I have points on all the Score-Drums of Player-2.
I start a new game --- due to the sneaked-in stripe of paper in Sw-near-1: Player-1-Score-Drum-1000s does NOT reset.
I sneak-in the stripe of paper in Sw-near-2 ... : Player-1-Score-Drum-10s does NOT reset.
I sneak-in the stripe of paper in Sw-near-3 ... : Player-1-Score-Drum-1s does NOT reset.
I sneak-in the stripe of paper in Sw-near-4 ... : Player-2-Score-Drum-1s does NOT reset.
I sneak-in the stripe of paper in Sw-away-1 ... : Player-2-Score-Drum-1000s does NOT reset.
I sneak-in the stripe of paper in Sw-away-2 ... : Player-2-Score-Drum-100s does NOT reset.
I sneak-in the stripe of paper in Sw-away-3 ... : Player-1-Score-Drum-100s does NOT reset.
I sneak-in the stripe of paper in Sw-away-4 ... : Player-2-Score-Drum-10s does NOT reset.
Maybe the wiring in Your Shangri La is the same --- Player-2-Score-Drum-1000s is resetted by Sw-away-1 --- maybe, most likely --- (maybe not ?)
Ask a friend to help --- these sneaked-in stripes of papers have the tendency to fall out.
Please - when You work on the pin: HAVE the main power cord unplugged (Safety Reasons).
Play a TWO-Player-Game --- have the Score-Drums to about 1121 and 1121 - pin comes to Game-Over. UNPLUG the main power cord - Sneak-in a stripe of paper in-between the blades on Sw-near-1 --- plug-in and start a new game --- the Player-1-Score-Drum-1000s does NOT reset - question: Is this true ? - also in Your pin ?
At the time one person plugs-in the main power cord and starts for a new game: The other person holds the sneaked-in stripe of paper in place.
Check all the 8 switches on the 1-2-Reset-Relay - THEN have a good look at the Switch causing the Player-2-Score-Drum-1000s not to reset --- closing when the relay actuates ? - contact-points clean ? wires soldered-on ? --- ALSO check the switches (same procedure) on Player-2-Score-Drum-1000s.
Greetings Rolf
0Shangri-La-1-2-Reset-Relay (resized).jpg0Shangri-La-3-4-Reset-Relay (resized).jpg
