New! Dark mode!
(Topic ID: 143771)
Shaker (Spike) DOA?
By Stack15
5 years ago
  • 30 posts
  • 11 Pinsiders participating
  • Latest reply 4 years ago by gripwhip
There have been 10 images uploaded to this topic. (View topic image gallery).
#1 5 years ago
Has anyone had an issue with a stern spike system shaker? I just put one in my WM. It was a very simple six step process - basically put it in, screw it down and plug it in. It doesn't do anything.
I don't know much about this spike system. But maybe did I blow a fuse? Anyone know what the orange light means on the side board? That is the only odd thing I see.
#2 5 years ago
Pictures
#3 5 years ago
There are some different shaker motors/boards out there.
Is the one you got for the Spike System ?
LTG : )™
#4 5 years ago
Yes. Stern Shaker Motor Kit (rev c) for Spike System games.
#5 5 years ago
Does it need to be enabled in the setup portal?
#6 5 years ago
Spike shaker = confirmed.
#7 5 years ago
And the shaker is set to maximal. Does anyone know if WrestleMania just isn't coded for a shaker? It is weird to have a DOA one.
#9 5 years ago
Is the game doing anything strange like not being able to start a game?
#10 5 years ago
No. Everything seems to work fine - just no shaker action. All signs point to either a DOA shaker or no game code for a shaker.
I will call stern when I get home.
#11 5 years ago
Had this same issue with mine. After calling Stern they sent out a new node board and it worked perfect after that.
#12 5 years ago
Thank you! That is most helpful.
#13 5 years ago
FYI That's not a Stern Shaker. That an Aftermarket Shaker. Can you test the shaker in another game?
#14 5 years ago
These aren't too hard to troubleshoot. The spike shakers have only two wires. It's a 12vdc shaker so you can give it a bit of 12vdc on those two wires and see if the shaker moves. If so, problem is upstream if not problem is shaker.
#15 5 years ago
WM is my only spike game - I mean there are only three to choose from. I am pretty sure the problem is with the stern board.
#16 5 years ago
Quoted from Stack15:
Just to be sure, double-check your shaker motor to ensure that there is NOT a small blue capacitor soldered to it, as pictured below:
Pinball Life originally had this blue capacitor connected to all of their Spike shaker motors, and it ended up taking out everyone's node board. They had to modify all future PBL Spike shaker motors by removing the blue capacitor (or you could just clip it off).
Just thought you could double-check to make sure that they didn't send you a pre-modified shaker by accident.
If yours never had a blue capacitor attached, then yeah, the issue is most likely the Stern node board.
#17 5 years ago
I called Stern. They picked up on the first ring and were extremely helpful. They are sending me a new "node board" - the little one on the inside of the cabinet.
#18 5 years ago
Thank you everyone. Stern asked me about the capacitor too. None here.
The weird thing = every other shaker I bought came with the side board.
#19 5 years ago
Yeah, this is one of the changes with all newer Spike games. The Spike shakers just plug right in to the game's existing node board. I'm glad to hear Stern is taking care of this for you.
#20 5 years ago
Quoted from markmon:
I'm surprised the shaker would only be +12v. The manual (WWE, KISS) doesn't tell what voltage that connection is, but I expected more than +12v.
#21 5 years ago
Quoted from DugFreez:
Same motor has been used forever. Always 12 volts.
LTG : )™
1 month later
#22 4 years ago
Over a month later = still no action. It is getting frustrating.
#23 4 years ago
What do you want us to do about it? It may not even be a node board. Did you power it with 12v to test like suggest in the start of this?
#24 4 years ago
You did not say if you recieved the new node board from stern,I had my node blow from a shaker
#25 4 years ago
It seems to be stuck in a loop. I called stern 30 days ago and went through the trouble shooting. They told me I needed a new node board, got my name and address and said there would be one in the mail. Ten days later and no package. I called back and stern told me they don't send things directly to owners and I needed to go through my distributor for the node board. I was confused because earlier it was quite clear they were sending one. I am not one of those people who always asks for the name and employee number of everyone they speak. Maybe I should have done that. We went through trouble shooting again and they said I need a new node board.
So I emailed my distributor. They said they would call stern. I followed up two days later and they asked for pictures. I sent those. Followed up six days later and apparently we are waiting on stern. That was five days ago. I have been oddly enough expecting a node board in the mail for over 30 days. I called stern 2x today. They are not answering. I left a message. What else am I supposed to do?
#26 4 years ago
Its obvious you need to burn their house down
#27 4 years ago
Hahaha. That made me laugh. Thank you.
Stern called back just now. Spoke with Chad and he was great! I think we will get it all straightened out in time for Christmas. I am admittedly kind of hard to deal with. I just want things to work as they should - hence I dumped all my 90s games for newer sterns.
#28 4 years ago
Hopefully in another week or so I can go back to being happy.
#29 4 years ago
1 Week Later: So any update?
1 month later
#30 4 years ago
I am having similar issues with a new GoT and a new shaker. It was one made for spike. No blue capicitor. I tested it with a 9 volt battery and it worked fine. It just does not work in the machine. It is set on maximum in the settings. Any way to test it through the menu? Bad node board? The game starts so I don't think it was the previous issue that these shakers were blowing the board.
$ 54.99
Pin Monk
Arcade Upkeep
$ 17.50
Pin Monk
$ 12.50
Gweem's Mods
$ 50.00
$ 65.00
Lighting - Backbox
Arcade Upkeep
$ 54.99
$ 54.99
$ 5,899.00
Gulf Coast Pinball, LLC
$ 50.00
Back Alley Creations
$ 229.99
$ 69.99
$ 1,000.00
Playfields
Pinball Playfields
$ 24.50
