Hi everybody,
i read some threads about installing a shaker in a WPC game.
Now i want to install shakers in my games.
But I'm not sure what is the best way.
The idea is to use a shaker with a seperate powersupply and trigger it by a flashlamp. Everytime the lamp flashes the shaker should shake.
The flashlamp pulse is to short to start the motor and this is why I would like to stretch the pulse for 0,5 - 1 sec.
But I'm not sure if the board is the right one for my idea: ebay.com link: DC 5V 12V 24V Adjustable Delay Time Turn Off Ne555 Timer 10A Relay Switch Board
I thought I could do it like this:
Use a 12VDC Shaker Motor with an 12VDC 10A powersupply (seperated).
The Triggerinput should be a Flasherlamp (20 - 24VDC ?) which is connected to a "Relay-Board".
The Delay adjusting is on the "Relay-Board" and will set to 0,5 or 1 sec.
Did need more components for example diodes on the triggercable to prevent return currents to the flasherlamp?
Hope you can help me to find the right way to get my shaker working.
Thank you
