Quoted from Pesmerga:Thank you very much! My cables were all soldered wrong. I have soldered them as indicated and the problem is solved! the wall mechanism is now working during play but it doesn't works in test mode.
If you are testing while the door is open you'll need to make sure to hold in the door switches so the high power is enabled... Otherwise I'm not sure what could cause that.
Quoted from Pesmerga:Also now the coils seems all weak (ball launcher needs 2-3 try) and i was wondering, may I expect some damage from the previous wrong soldering?
I don't know. I recommend putting that in another thread and perhaps someone else will be able to advise.
Quoted from Pesmerga:I'm also having an error with mini playfield: ER. MINI PFD. BAD CHK. SWITCHES/MTR (not related to the soldering works because it was already there) should I open another post for this error? I have checked solderings on kicker's coil here but they don't seems loose!
Here's what the manual states:
I'd start out easy... If the motor can move left/right then that should be fine... and it could be the opto's to detect when it is all the way left or right... or the fuse... if none of those then dig into the more difficult things (driver and cpu boards, etc.) Again not an area I'm an expert at so perhaps a new thread or searching on old threads would work.
Good luck!
