It's late & I'm tired, and I'm in a hurry to prep games for a show, so this is just a sanity check.
I've been working on a shadow. Did a bunch of repairs (replaced brick wall drop target, replaced plastic under left phurba ramp, replaced mini playfield IDC connector, fixed a pulled wire from another mini playfield connector, fixed disconnected wire from mongol target 52).
I was doing a final play test, everything went fine. Then I lifted the playfield, went to eject the balls, and row 4 shorted to gnd.
So, in switch test, all row 4 switches are closed.
If I try to activate any other switches, that entire row fires off all its switches.
With the switch connectors disconnected from the MPU, except for j205, no closed shorts in the edge test.
When I try to step through the rows & columns by jumping connector pins on the MPU, columns 1 & 2 fire off a bunch of switches. All other rows/columns only activate a single switch.
So, I'm assuming blown U20?
