I desoldered cleaned and rechecked now I assume it may be the cable join someone has done so thats my next continuity to check.
I could do with replacing a couple parts of the mini kicker if anyone knows the part numbers (I cant find them and they arnt in the manual that i can see)
the metal bracket the shaft with the square end goes through this one looks doctored as if not the original.
the spring this one has 2 very weak ones neither of which are the right ones I think.
solenoid re soldered and redid the join (better), got continuity but no life in it still grr. Any ideas? where should I be looking?
tested the fuses 2 dead which are for gi's so hopefully once ive fixed the burnt connector that will be the light prob sorted fingers crossed.
Found the second switch error its switch 55 micro switch for the single yellow drop target. it seems to work intermitently works when i press it but on it but only sometimes when the target drops. Do you think this is a new switch and diode jobbie?
