Greetings - I need some help with my Shadow’s Sanctum wall drop target plastic. I’m having increasingly frequent cracks at the bottom of the drop target. This causes the lifter arm to then wedge the broken target around the post keeping it in line.
I had this happen once a couple of years ago and it’s now happened 3 times in very limited play.
I believe the issue is that the arm is lifting it and it doesn’t have any play between the actuation and the contact with the post. Looking at the diagram in the manual and going from my memory of the last time I had the assembly out of the game, I don’t recall a way to adjust the upwards throw of the actuation. Just the resting height of the target when it’s down.
Any ideas on what the cause is and how to remedy it?
The Sanctum is otherwise reliable and working fine. The assembly doesn’t seem like it has excessive slop in it.
