(Topic ID: 34417)
Shadow restoration(updated Feb.)
By TheRave
7 years ago
  • 52 posts
  • 21 Pinsiders participating
  • Latest reply 6 years ago by Aurich
There have been 28 images uploaded to this topic. (View topic image gallery).
There are 52 posts in this topic. You are on page 1 of 2.
#1 7 years ago
Here is an update to my Shadow teardown and restoration process. I was able to shoot a coat of clear, cut it, and shoot another coat. I'm hoping this will be all I need so I am stalled waiting for it to set hard for a couple of days. I'm really pleased so far! Fingers crossed that this coat sets well!
Here's the original damage:
#2 7 years ago
Here are some resto pics:
#3 7 years ago
Paint:
sanctum_taped_airbrushed.jpg // Error: Image 61738 not found // sanctum_painted_no_text.jpg
#4 7 years ago
more paint:
#5 7 years ago
Here's where things got interesting. I tried to make a silk screen for the sanctum text with mixed results. In the end I printed onto clear label stickers and went that route. Silk screen could have worked well, it was user error. The last pic is the sticker prior to CC.
#6 7 years ago
Shot the CC over the last two days. 2 full coats with 1 cut between. This is hopefully the last coat before cut and buff. We'll see.
#7 7 years ago
Beauty
#8 7 years ago
nice
#9 7 years ago
Rave, your rails will be shipped back Monday or Tuesday
Also make sure to put a Mylar over the sanctum anyway. Even if cleared. The sanctum action is particularly abusive.
#10 7 years ago
Thanks Alex! No real rush. This machine is starting to come together. Your work on those rails should really set it off.
#11 7 years ago
Looking great!
What did you use to fill in the sanctum wear?
#12 7 years ago
I used dolphin glaze. It was very easy to work with. I'm sure there are other recommendations such as JB weld and other epoxy fillers. I can say that this stuff was easy to use, an I'm hoping it remains durable. I think it will with the CC, but I will probably mylar the area for the sake of not going through this process a second time. Here's the link:
amazon.com link »
#13 7 years ago
Psyched on the decal not lifting and almost completely invisible!
#14 7 years ago
VERY NICE work on the Sanctum.
-9
#15 7 years ago
Honestly, I wouldn't waste your time. You can buy a ZOW or HULKLE and have a brand new machine today.
#16 7 years ago
Quoted from wendell:
Boo!
Nice work Rave.
#17 7 years ago
Rave your rails are done
#18 7 years ago
Glad you attempted this yourself and didnt send it my way. Wasn't do bad was it
Did you print on waterside decals? What kind of printer?
#19 7 years ago
Your Shadow is going to turn out great.
#20 7 years ago
I printed with a laser printer onto clear shipping labels purchased at Staples. I was running out of ideas after the failure with the screen print. It worked out, and it has been a really fun project. It takes a lot of patience having a disassembled machine in the living room though!
#21 7 years ago
Great job - looks fanatastic. Did you clear coat the entire playfield or only your work on the sanctum?
#22 7 years ago
CC'd the whole playfield. It's nasty stuff! I'm hoping that it cuts flat so I won't have to use it again.
#23 7 years ago
What did you clear it with?
#24 7 years ago
2 part urethane automotive clear. Added some enhancer to get it to lie flatter. I can send you a link if you want the exact stuff.
#25 7 years ago
Quoted from TheRave:
Not necessary, but thanks. Just curious.
#26 7 years ago
Amazing work! Attention to detail really pays off. Great work!
#27 7 years ago
Update:
I was able to cut the clear flat. Sanded down to 2500 and buffed a few times. Nice and shiny even before wax!
#28 7 years ago
Also spot welded the ramps and re-grained. Almost time for reassembly!
#29 7 years ago
Nice looking Sanctum you've got there
#30 7 years ago
How did you cut the playfield?
Also what did you use to regrain and the links to the clear coat?
I want to do spot clear on 2 of my shooter lanes then maybe my HS2
#31 7 years ago
I cut the orange peel with a lite 800 grit wet sand. Then 1000, 1500, 2000, and 2500 wet sand. Then used a buffing compound to get rid of any fine scratches. To regrain I used a bit of mothers metal polish and 800 grit paper, then hit it again with a green scotch brite. Here are the links to the clear. Keep in mind that this stuff is nasty and all precautions need to be taken. In my opinion I wouldn't go through the trouble of using this unless you were going to do the whole playfield. I think there are easier ways that you can read up on here: http://www.pinrepair.com/clear/index.htm
There are a bunch of clears listed on there as well.
link to clears I used:
Part A: http://www.tcpglobal.com/Customshop/itemdetail.aspx?itemno=KUS+KC2020-QT
Part B: http://www.tcpglobal.com/Customshop/itemdetail.aspx?itemno=KUS+KH2021-HP
Enhancer: http://www.tcpglobal.com/Customshop/itemdetail.aspx?itemno=KUS+KE218-HP
-9
#32 7 years ago
You shouldn't have spot welded those ramps. If you had any clue you would have GTAW'd them. NOOB.
#33 7 years ago
Looks amazing! I am just north of Hartford and have a Shadow that I replaced the playfield on over 10 years ago....you did an amazing job blending the colors! Great work!
Chris
#34 7 years ago
Quoted from CFoote:
Yeah Rave,kudos all around! I too am afflicted with the same sanctum issue, how did you apply the grey and how did you match it so well?
#35 7 years ago
Thanks dudes! You can see in one of the pics that I taped off that whole section and sprayed it all the same color. I tried matching with marginal success, and ended up using Apple Barrel Country grey acrylic paint. I shot it with a small gravity fed hobby air gun. I think the gun and hose were on $15 on amazon. I can find a link if you're interested. The grey matches decent when you can do a whole block. It's noticeable if you try and blend.
#36 7 years ago
Trying to get those ramps done for you dude so I can get them out the door. I want to see them done on the machine!
#37 7 years ago
Thanks Rave, no need for the link, I was just curious what color you used. I figured you sprayed it somehow, it looked too good to be brushed on. Great job!
#38 7 years ago
It's cool Alex. I have to leave for a business trip from Monday until Sunday. Once I'm back I'll start to reassemble. If you can ship them to be here right after the 20th, that would be ideal. That will give you a bit of time as well. Thanks.
#39 7 years ago
Doing brass powder Alex? My shadow came with fresh brass played wireforms from mike chestnut and it looks so beautiful. Curious to see how this compares.
#40 7 years ago
No Brass. I want to murder this whole machine out in black, even the cabinet hardware. He's powdering them sparcoal, which you can imagine is charcoal with a metallic to it. Not sticking to original colors, sorry to all the purists out there.
#41 7 years ago
I look forward to seeing pics of that for sure
1 month later
#42 7 years ago
I finally got the playfield fully populated and operational. I forgot how much stuff is jammed into this machine. It went back together smoothly. The only real tweaking needed was the plunger on the mini playfield would not engage. Easy fix. The playfield is amazingly flat and fast. Almost unplayable fast! Props to Alex for the wireforms. I wish I could get a better pic. I think the sparcoal was a great color choice, and love how it looks!
#43 7 years ago
And cointaker LEDs throughout. No issues with defective bulbs at all.
#44 7 years ago
I needed to get some games in on this restored playfield. I still plan on touching up the cabinet, but that will have to wait until spring. I'll have pics of the new backglass soon. I can't wait for the CPR plastic set. THIS MACHINE NEEDS THEM!
#45 7 years ago
Looks great! Nice work
#46 7 years ago
Glad you like them Rave. That color would look great on almost any machine but the shadow is the perfect theme for them.
#47 7 years ago
Looks good, nice work.
#48 7 years ago
looks great, fantastic job
#49 7 years ago
Amazing job
#50 7 years ago
I think this will look awesome with the all black hardware once it's done. I put the alt translite on and an all black Bally speaker panel on it. Looking forward to a finished product soon.
5,200
Sale Pending!
Plymouth, MN
KAHR.US Circuits
Gweem's Mods
New Westminster, BC
Pin Mods
