Motor isn't turning, switches that let the game know aren't working.
If it was okay before the swap, it is something you did or missed.
LTG : )™
Quoted from RGAires:Any ideia where to start?
See if motor works, then see if switches work.
LTG : )™
The Operations Manual say this
"ER. MINI PFD. BAD CHK. SWITCHESlMTRThis is saying the mini-playfield is not working correctly. Check the mini-playfield motor (20 - minimotor left, 19 - mini motor right), Bridge driver board, Power Driver board, CPU board, and thetwo mini-playfield limit switches (38 - mini-playfield right and 37 - mini-playfield left). Also checkfor blown fuses."
Witch is the best way to test this?!
Regards
In tests there must be a mini playfield test. Then see if you have power at the motor ? if not follow along the way back to the power driver board and figure out where you lost power.
LTG : )™
This page was printed from https://pinside.com/pinball/forum/topic/shadow-mini-playfield and we tried optimising it for printing. Some page elements may have been deliberately hidden.
