Please advise me on proper switch setting.
As I understand this switch, it is always open, then closed when the button is depressed partially, then switched yet again - this time to the EOS portion of the switch - when the button is pressed completely.
I have a newish Stern SAM pin but I worry my switches aren't reaching "EOS" and are keeping the coils in high-voltage when they should be ultra-low voltage. Why do I suspect this? Well, when I cradle the ball, I can hear the coil buzzing. If I had to describe the present orientation of the leaves of the switches, I would say it looks like three, evenly spaced fingers, each about 1.5mm away from the next.
Any suggestions would be *much* appreciated.
Thanks for reading my post!
Jason
