Archived ad
Pinside keeps a record of old ads in its Market Archive, for historical purposes and as a price reference. This ad has been ended by its seller and is now archived.
Parts - for sale
Servo and Arm for D.E. TOMMY
Added: 2016-03-11 23:00:00 UTC
• Re-listed: 2 times (July 16th, 2016)
• Ended: September 6th, 2016
Condition: New (selling multiple, business)
Price
$ 89
Drop in Replacement Servo and Arm assembly to operate the blinders for Data East Tommy. This is a drop in replacement, no mods required to the mounting bracket in your game. The price is $89.00 Shipped to the USA. International shipping available.
I changed brands from the original servo used to get a stronger gear train, after reading that the original servo had a history of gear train failure. Hitec the maker of the servo I used says that their Karbonite gears are 4x stronger stronger than the standard white nylon gears. And according to the manufacturer's advertising: after hundreds of thousands of cycles the gears do not show any signs of wear.
The arm I make is made from 6061-T6 aluminum fitted to a modified heavy duty servo arm. The roller assembly is a hardened and ground steel pin with a roller made from glass filled resin. This set up provides a free running operation. Note my arm will not fit the original Airtronics servo.
I tested my servo.arm assembly out in a working game at the Ann Arbor Pinball Museum. The New Servo and Arm works great! Travel adjustments may be required to the servo's movements using the potentiometers on the servo driver board using the "arch" command. In further tests using a Hangar 9 Digital servo current & volt meter. I found the servo I used drew about half the current, than the original servo, while moving the blinders. And one fourth the current while holding the blinders open & closed. My first production arm and servo is now in operation at the Ann Arbor Pinball Museum. The original plastic arm had a crack in it by the pin and roller. See pictures 2 & 3.
The price is $89.00 Shipped to the USA. International shipping available. Check, money order, Paypal.
Please use Pinside Mail to contact me for my Paypal address or snail mail address. Thank you, Bob E
I have two of these in stock as of 7/15/2016.
Contact
Note! This is an archived ad. No longer for sale!
Seller insights
These are bob_e's market stats.
Listing result
The seller ended this ad and submitted the final sales price into our price database but opted not to disclose the price publicly.
