(Topic ID: 142921)
Service outlet inside cabinet
By Plumonium
  • 26 posts
  • 15 Pinsiders participating
  • Latest reply 1 year ago by Plumonium
  • Topic is favorited by 7 Pinsiders
    #1 4 years ago
    Can I plug anything in the service outlet WHILE the game is running? Like a 12 volts led strip using an AC adapter?
    Can it lead to problem and should only use it when the game is turned OFF?
    #2 4 years ago
    You can use it. Bear in mind anything you plug into it will be on all the time the game is plugged in, whether turned on or off.
    LTG : )™
    #3 4 years ago
    Echoing Lloyds comments, it is not a switched outlet. When the game is plugged into the wall, the outlet is hot and not affected by the on/off switch on the game. You would need another switch to control the led lighting. OR, you could just put the pin on a power strip with a surge protector and a switch and use that.
    G
    #4 4 years ago
    I use the service outlet in my LOTR to power some interactive LED strips that light up a Gollum and Gandalf figure on top of the backbox. I just turn the LED strips on and off using a remote control outlet that's plugged into the service outlet. Bought the remote control at Costco. It's similar to this one from Amazon (but I haven't tried the Amazon one):
    amazon.com link »
    #5 4 years ago
    It would take you 5 minutes to wire the service outlet to the power switch, causing it to go on and off with the game.
    #6 4 years ago
    Don't plug anything into the service outlet that draws over 100 watts or you'll blow the machine's main line fuse. It was never intended to power anything more than a clamp light or a soldering iron.
    #7 4 years ago
    I've got my TZ cab LEDs in a switched service outlet with a 12V power supply. No need for surge protectors or remote controls.
    #8 4 years ago
    An alternative to making the service outlet switched is simply wiring the mod power supply to the bill accepter 120v
    10
    #9 4 years ago
    Don't try plugging in a vacuum cleaner in either blows fuse right away. How do I know?
    #10 4 years ago
    Quoted from CNKay:
    #11 4 years ago
    Quoted from CNKay:
    Or an electric drill.
    #12 4 years ago
    Yeah I think mine had a two and a half amp fuse. I'm surprised you can plug a soldering iron in. I thought it would have been un fused outlet able to handle what the main cord could just like an extension cord. Definitely NOT the case.
    #13 4 years ago
    The main 8A fuse is after the service outlet. You should be able to plug in whatever the line cord amperage is.
    3 years later
    #14 1 year ago
    Quoted from vid1900:
    Does anyone have detailed instructions with pics on how to do this?
    There's this thread https://pinside.com/pinball/forum/topic/poor-mans-sub-addition but the pics aren't that clear to me.
    I want to power some LED strips off the service outlet but don't want to blow up the machine or kill myself in the process.
    I want to do it on my Johnny Mnemonic (WPC-S)
    #15 1 year ago
    Quoted from dluth:
    Unplug the machine, unscrew the power box from the cabinet. Take a good pic of the inside of the power box showing the wiring. I will show you which wire to remove and where to reconnect it.
    #16 1 year ago
    http://www.flippers.be/power_wiring.html
    Do this at your own risk - unplug the machine from the wall !
    #17 1 year ago
    Quoted from GRUMPY:
    Thanks! Does this help?
    #18 1 year ago
    Pic is just fine. Any other questions just ask.
    #19 1 year ago
    Quoted from GRUMPY:
    Could it be possible to add a switch? So it's either one setup or the other on a flip of a switch.
    Best of both world. Not sure how it would look though...
    #20 1 year ago
    Thanks, I think that makes sense! So I don't need to do anything to the white wires as http://www.flippers.be/power_wiring.html suggests?
    #21 1 year ago
    Quoted from dluth:
    No, it's not needed.
    Quoted from Plumonium:
    Yes if you use the correct switch. You need a double pole, on, on switch.
    #22 1 year ago
    Can you plug in another pin?
    #23 1 year ago
    Quoted from Crash:
    Sure if you limit it to just one.
    #24 1 year ago
    Thanks GRUMPY and aeneas, I’ve had success. I’ve wanted to do this for a while but was too nervous to try, but it was pretty straightforward with your help.
    #25 1 year ago
    https://www.digikey.com/product-detail/en/carling-technologies/2FB53-73-TABS/432-1076-ND/483648
    Lets say you drill a hole (red star) next to the fuse and mount the switch.
    Then take the black wire from the service outlet and cut it in the middle between the crimp connector and service outlet so both wire ends can reach the new switch.
    Add a pink crimp spade connector to each of the 2 black wires ends, install the black wire from the service outlet to the center terminal of the switch, install the other black wire to one of the outer switch terminals. For the last wire, take the left black wire from the fuse holder and cut it @ 2 inches from the pink connector. Take both cut ends of the black wire and put them together in a yellow crimp spade connector and install it on the last switch terminal.
    $ 229.99
    $ 29.99
    Full Tilt Pinball LEDs
    nvram.weebly.com
    Professor Pinball
    $ 16.00
    £ 37.00
    PinballToys
    Metal-Mods
    $ 33.50
    Iron Monger Decal Out of stock
    Flashinstinct
    $ 69.99
    $ 28.00
    Pin Monk
    $ 119.99
    $ 29.99
    PinWoofer
    $ 76.95
    $ 89.99
    $ 14.00
    $ 54.99
    $ 96.95
