Hello everyone
I'm new to this forum and also fairly new to the pinball scene .
I have a question regarding the Jurassic Park pinball from Sega.
Before I do any further investigation, I just would like to read your opinion to it if my assumption is correct.
When I try to start the pinball, it constanly reboots. You can hear the booting sound that the Sega machines do at the start and after a few seconds you can hear it again and again.
Looking at the backbox, I saw that 2 LED were not on on the I/Q Power Driver Board, L200 and L201. L204 keeps flashing. All other LEDs are working.
Could this be a watchdog issue? On the CPU Board the L201 is on though for the 5V.
I also noticed that U210 (DS1232) Pin 3 has already been clipt off by the previous owner. Need to check if U218 has also been clipt on PIN 3... I forgot to check this.
I assume I would need to measure certain components were the 5V goes through and replace if needed.
Could it be also a different problem?
Thank you in advance for your replies!
Wishing you all a wonderful day
