Hi Tekman,
I see what's happening. Or, rather, what's not happening. First, neither submission is in my work queue. However, our Active Listings File shows that somebody has activated the Submission Tool for each of them (I see an associated email address but I won't reveal it here), a file has been added for each game, but each Submission was not successfully submitted yet. From my end, each looks like you are still actively operating the Submission Tool at this very moment. Only because you have told me that you are not actively in them can I conclude they are in an abandoned state, which means I'd never see them in queue, and eventually (a few days?) they'd drop out of the abandoned status and disappear as if they never happened. That may explain instances where things were believed to have been sent then... nothing is ever heard back from me.
You may have done everything exactly right and we may have a problem on our end. However, if ever you are submitting and you fatfinger and accidentally blow the screen away, or you do not click the "final button" but instead close the window in any other manner, your submission becomes abandoned and it waits a few days for you to pick it back up and continue where you left off, before it deletes itself. And I'll never know.
So, what I'd like you to do, please, is go to the [Settings] link found on any IPDB page, click on it, and then in the right column, about the third or fourth block down, will be a block called "Abandoned Submissions". (This block only appears if you have abandoned submissions.) You should see both of your submissions there. Focusing on only one at a time, click [Try to Re-Edit] and you will be placed back into your open Submission, almost always right where you last left it (once in a while it drops your last-added details). You want to get back to the Main Page of the Submission where the "flashing arrow" is at the top (if you are not already there), then scroll all the way down to the very bottom of this Main Page, and click on "Submit Update for Review". That is the final button, the correct button to click which sends your submission into my work queue. Any other method of closing out the Form will result in an abandoned (and unseen) submission as described earlier. When you have done this, go back to [Settings] and do your other submission in the same way.
If you believe you originally did do it the prescribed way, please do the above anyway, and I'll take a new look.
Thank you!
Jay
P.S. Because you included your email address in the space provided for it on the Form, you can look anytime at the [Settings] link and on the right side is a block listing all of your "Submissions waiting in Queue" to confirm your submission arrived, and when it arrived.
